P1000 NBomars tinkering and silly stuff
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Want to take the lift off. Never wanted it in the first place. @Tigermark talked me into it. I should be able to run these with just forward arms.
Hes a 2 way agent..he tried to talk me and @Ragnar406 out of takin it off.
nbomar
nbomar
4,416
17,855
Springdale, AR
Haha...they do look considerably smaller than the roctanes though.
E64b94f4ccdb082bd1a60a94f32fe6e8
Not here. They have no air and roctanes are mounted and at 12psi. They aren’t as squared off and wide I think.
Tigermark
Tigermark
Outside looking in.
The Rocktanes talked you into it. I tried to talk you out of getting the Rocktanes;)
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Did I miss it ? What size are the new tires?
Reactions: BWAF and sharp
nbomar
nbomar
4,416
17,855
Springdale, AR
@GlockMeister @Ragnar406 can one of you give me eye to eye measurements on your front and rear shocks bow that you have adjusted to clear your tires without the lift?
Reactions: sharp and Ragnar406
I think you’re asking for 2.5” on the front and 2.75” on the rear that’s silver showing. Pretty sure that’s what they said they are running
Reactions: sharp
nbomar
nbomar
4,416
17,855
Springdale, AR
I have a different shock so the bodies might not be the same I need overall measurement of eye to eye.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I probably still have a bit of adjustment I need to do so these are probably not final measurements
17.5” in front
19” in back ( back may not be fully settled) and I think 19” is also what I had with the lift on.
Middle of bolt to middle of bolt
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Reactions: sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I wanna say i lost right around an inch so...19 front..19 3/4 rear..
Reactions: sharp
nbomar
nbomar
4,416
17,855
Springdale, AR
I’m at 17.25 front and 18.25ish in the rear. Bolt to bolt center with the lift on. Might add a .5 inch in the front and .5-.75 in the rear and remove the bracket lift.
Hmmm choices!
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Hmmm choices!
I thought that was the goal to remove the lift anyway
