P500 Tip Out Windshild molding
rtn001
rtn001
317
945
Central Florida
The passenger side molding on my Tip Out Windshild got pulled off by a vine my first time out. Now it will not stay on. Thought about using 3M trim adhesive or something like it but I am afraid I may not be able to remove the trim at a later date if needed. Any thoughts or ideas?
Russ989
Russ989
22,642
147,257
Take a pair or pliers and put the squeeze to it in a few places, the metal channels inside the rubber will pinch down and it will be almost like new. I’ve been there and done that already.
Chooglin
X2
Reactions: rtn001
rtn001
rtn001
317
945
Central Florida
RUSS989 Thanks again. It worked. Now lets see how long it stays on. There is a lot of vines on one of the trails I have to use to get to one of my deer stands. I may have to do some of the dreaded four letter W--k word and cut it out. GRRRRRR
Reactions: Chooglin
Russ989
Russ989
22,642
147,257
No problem, sounds like you need a good machete to cut those vines down. Correction,
W- -k is a four letter dirty word....unless it affords more pioneer accessories lol.
Reactions: rtn001
Buford
Buford
362
586
U.S.A.
Honda sells the weatherstripping kit for those windshields, comes with all 4 pieces.
I don't even use a pliers to squeeze them , easy to just do it with your fingers.
rtn001
rtn001
317
945
Central Florida
I saw one of mine trying to escape. Used 3m weather stripping adehesive. Worked great.
I don't know if mine is going to stay on or not. I haven't been able to use it sence I put the squeeze on it. If it works, great, if not I'll go for the bigger hammer.
Reactions: Stacy
Stacy
Stacy
181
573
Twin falls idaho
That 3m stuff is awesome,I use it at work a lot. I put a bead all the way around and let it set overnight clamped. Formed the gasket perfectly to the curves better than before. Beware keep it of your hands or you will be wearing it for a week.
Reactions: rtn001
rtn001
rtn001
317
945
Central Florida
I've got the feeling I'll be using it. That lower corner is looking for something to grab it. I used the 3M trim and molding adhesive years ago and it worked great.
Reactions: Stacy
