P700m4 Tire and Wheel size suggestions
Jake62
5
Texas
Need some suggestions. Going from stock wheel/tires on P700R4 to 14". How tall would yall suggest for me without dropping too much power? Never been stuck with the stock setup, just high-centered, so I need a little more clearance. Mostly mud and hard pack.
Deerhunterrob
Deerhunterrob
57
85
NE ALABAMA
I run 28s on 16 model they robbed sum power but their mud tires
Welcome to the forum.
If you haven't gotten stuck, I would suggest get some 27" tires but stay with 12" wheels. The 14" wheels make you loose too much side wall and you can cut a tire. A general rule is 28" and above you can use 14" and 28" and down you can use 12".
To help with the ground clearance, get yourself a Strong Made lift kit and that will get the belly up high. Stay away from the High Lifter for the P700. It will tear stuff up quick.
swsebek
swsebek
2,854
5,835
pa
Welcome to forum,I run 28"Big Horns with front shock spacer and it's not to bad.They only rub a little on the mudd busters bolt heads.But it tolerable.
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
The easiest way to lift it is with spring spacers that you can cut yourself. (Search previous threads in the 700 Modification forum)
A lift will also work. @joeymt33 is right. The Highlifter design induces too much stress.
As for tire size... I'm running 28.5" on 14" rims. I don't have any rubbing but tire design can be different. A squared off tread WILL rub.
Depending on how you bottomed out, you might need arched A-arms.
Reactions: joeymt33
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
I had 27 inch tires with 12 inch rims worked great. They were ITP Mega mayhem's. On STI 12 inch HD 3 rims
lonewolf
lonewolf
96
137
Louisiana
I just bought a set of Interco Interforce, in 27x10-12. I think they would be a great tire for the P500, or the P700. I agree with many of the others on 27" height, and staying with 12" wheels. These tires run a true 27" height, after I mounted them. As far as wheel size, I personally rather the 12" wheel over the 14" wheel, even if I went up to 30" tires. I like the idea of more sidewall, and better floatation type performance. They will ride better, and flex better out on the trail.
IMG 0721
Reactions: swsebek
Jake62
5
Texas
Thanks! Do you have a lift? Much cheaper to keep the stock wheels. How much power loss with the 27s?
lonewolf
lonewolf
96
137
Louisiana
It's not on a P700, it's on my Honda Foreman. I was only suggesting looking at them, as I think they would make a nice choice. I'm going to buy a P500 in the near future and I plan to buy a second set for it. I like these tires because they are 6ply on the foot, but flex enough on the sidewall to still maintain a good ride. Yes if you don't mind the stock wheels they would mount on them nicely.
I can only speculate about the power loss with 27" tires on a a P700, and I'm sure others can speak from experience, but I'd think it would not hurt the power too bad. My foreman 500 turns them with ease. It even steers much better. I'm thinking once you go 28"-30" I'd think you'd definately have some trade offs, with power, and you'd probably need a lift.
Jake62
5
Texas
Thanks for all of the input! I installed a set of Interco Interforce 27" on the stock wheels. Man, what a difference! Steering is easier and they DIG. I don't know if I will need 4X again.....then again (hehehe)
Added 2.5" Strong Made lift on front and set the rear springs almost all the way up, too. I now have 11.5" front/rear clearance under the belly. Luvin' it so far!
Thanks again!
