Tire questions
Ridinfool
Ridinfool
36,144
386,049
Western North Carolina
Guys you are so real to me! But now I need I need to go back to reality and go to bed! HA! I found my marbles! Good night guys!
Marbles or nuts?
I think there’s a thread about some guy leaving his nuts laying around and his wife ran them over
NewHere2
NewHere2
Village Idiot In Training
55,911
395,796
High Plains of SD
Another advantage to using helium in my tires is,
If one gets a slow leak I’ll know it right away, if me or my passengers start talking like chipmunks it will be a sure sign.
So ya don’t offend the Bud Lite crowd, 🌈 . Wood dunt the correct noun be “Themlium or Theylium” not Helium ??
Just in case some one is a “Pro” ya should use the proper “Pro noun”. It’s so confusing nowadays.
Ridinfool
Ridinfool
36,144
386,049
If the LGBQRSTUVWXYZ crowd is Ofended by the word helium, maybe they should start using acetylene… that will show us…
Ridinfool
Ridinfool
36,144
386,049
Just had a thought,
When I drive on asphalt I’m not sure if the helium in my tires will lift the buggy up enough to keep the weight of the buggy up off the tires causing the tires to heat up and increase PSI…
What if I use insulation to fill my tires?
That should help keep the heat down therefore maintaining the set PSI.
Insulation to be used
34748244 D58D 4370 B268 1CDB628348AC
GovtMule
GovtMule
21,746
185,902
Tennessee
Just had a thought,
As long as it isn’t asbestos you’ll be good. That’s highly flammable when mixed with the helium.
211,636
Just had a thought,
When you compress insulation, it losses it's value?
Ridinfool
Ridinfool
36,144
386,049
