P1000m5 Tire recommendation
N
Noble1
Grand Rapids, MI
Just purchased a pioneer 1000-5... looking to upgrade the wheels and tires. I have been searching for a good all around tire. I will be hitting the trails, some road riding maybe some lite mudding. I live in MI and plan to use it year round so the tire will need to be decent in the snow as well. I have been looking at the following and looking for suggestions and or alternatives. Not looking to lift as I’m trying to keep it a bit more stable.
Rock a Billy’s
Terrabites
Moto claws
Rocktanes
Looking for a 28x10x14
Reactions: Plumber32
265,448
Rock a Billy’s
Terrabites
Moto claws
Rocktanes
Also look at STI Black Diamond tires, Good all around, reports of being very good in snow.
N
Noble1
Grand Rapids, MI
Good choices.. I went with terrabites but the others are fine too. 28x10x14 on all 4
Do you have a lift and or wheel spacers? Did you put them on the stock wheels? You have any pics of your ride with the terrabites on it?
High lifter lift and no wheel spacers... yes, on stock deluxe wheels. With Fox shocks around it.
2AA36E69 F3EC 47A3 9488 0E1471C5F42A 686A0F49 60C7 43BE A5EB AD645FA75C60
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
Quadboss QBT846 tires in 28x10 size on stock wheels. I also have fox shocks.
Love the shocks and tires
IMG 20171021 143716406 HDR
Reactions: Sckottty and Bigtee
W
wyodlr
147
209
Cody Wyoming
DesertRat
DesertRat
25
23
Phoenix, AZ
You should get at least 25,000 out of a set of Grabbers , I've had them on 3 different machines ,my last one had over 8,500 miles on them and still over 80% tread
At 4,500 miles since the beginning of August, I’m just starting on my second set. They were about half worn out, tread wise, and seemed to become more vulnerable to sharp rocks and cacti, making holes that couldn’t be repaired.
Discount tire replaced them under warranty ($50/tire) so all is good.
So I suppose it’s just how and where they get driven - mine were a combination of high speed pavement and rocky mountain trails with some low desert (cactus needles) thrown in.
On a previous machine, at lower speeds (sub 30 mph) I still had about half the tread left after 5,000 miles. I was starting to think about new tires, but sold the machine - a 700-4.
Sckottty
Sckottty
35
Abilene TX
do you know of any using 14”x10” factory delux rim on all four corners?
gullyjumper
gullyjumper
950
2,413
cookeville tn
Several of us are using factory wheels with 14x10 tires
I just got the tusk terribites 10x28x14 to go on stock p-1000-3 wheels {have to waite till Christmas to mount } can you tell me if the front tires stick out wider in fornt or the same wigth as the back ? Thanks
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
On stock wheels with 28x10 tires the front tire track width will be about 3/4-1" wider than the rears.
Reactions: JTW
The front should be 1” wider.. wheels are the same so the tires in the front are one inch wider and tires in the back are one inch narrower.. that means 1/2” on either side of the wheel so between the front and back 1” overall wider in the front than the back.
gullyjumper
gullyjumper
950
2,413
cookeville tn
Did you use wheel spacers in the rear and if so what size ? Or is it even noticeable without spacers ?
I have not... yet.
I have noticed with a heavy load it’s a bit more tippy. But that’s with the HL lift on also.
39,079
Since you’re putting these tires on the stock wheels, you won’t notice much difference at all.
The guys that use aftermarket wheels that are the same size all the way around will notice that the rear track width is about 2 inches more narrow.
Flgator_80
Flgator_80
274
422
Lexington, Tn
So if you use aftermarket wheels would you want 1" spacers on the back to even out or not a big deal?
