I have a 2021 pk1-5 with high lifter front and rear A arms and a SATV bracket lift with 1.5 spacers on back I have 30 x10x14 carnivores on it now With no problem s can I go up to 32 s or 33 s Has anyone tried this
1st off, rule #4 POIDH right @Remington ?I have a 2021 pk1-5 with high lifter front and rear A arms and a SATV bracket lift with 1.5 spacers on back I have 30 x10x14 carnivores on it now With no problem s can I go up to 32 s or 33 s Has anyone tried this
Roger that!1st off, rule #4 POIDH right @Remington ?
I wouldn't go past "true to size 30s" (even if you could fit them) with out some sort of gear reduction..........unless all you ride is blacktop.I have a 2021 pk1-5 with high lifter front and rear A arms and a SATV bracket lift with 1.5 spacers on back I have 30 x10x14 carnivores on it now With no problem s can I go up to 32 s or 33 s Has anyone tried this
Ditch that suspension that messes your suspension geometry up all to hell. And since you have arms, just add some preload to your shocks to get that lift (hope u have aftermarket shocks?)SATV bracket lift
Oh man! C’mon Jennay! I was gonna offer you a whole quarter for those🫣👍🏻🥳And please, no low ball offers
HUH HUH HUH He said “Penal” HUH HUHRoger that!
Hes in violation of Forum penal code# 6969
I have a low ball I can offer you! Its called….And please, no low ball offers.
That highly sought after slightly used banana costume offer still applies…Also, if anyone is interested in "go big or go home".......I have a set of Amish 40" wheels that wood look killer on any ride.
And please, no low ball offers.......I know what I got.
BLAHAHAHAHAHDJFBRKENXIXNWKCMDThat highly sought after slightly used banana costume offer still applies…
So I don’t break any penalsFor sale or trade one slightly used banana costume left over from a house party.
Asking $20.00or trade for SXS parts.View attachment 240575
paint flat black, add a metalmalisha sticker, claim 4" lift/6" if u have a bracket lift - u will get a koolaid drinker to drop some benjamins.....Also, if anyone is interested in "go big or go home".......I have a set of Amish 40" wheels that wood look killer on any ride.
Oh hell yeah!🤟🏻metalmalisha sticker,
That's a slippery slope.....That highly sought after slightly used banana costume offer still applies…
44's but you have to get the V8 option.I have a 2021 pk1-5 with high lifter front and rear A arms and a SATV bracket lift with 1.5 spacers on back I have 30 x10x14 carnivores on it now With no problem s can I go up to 32 s or 33 s Has anyone tried this
So the Max size you can go without rubbing? 30" if you go more than that and your at full lock or shocks are compressed the tire will rub the fender. The Offset is the biggest problem. The Rear arms have no offset. they are only the lower arms right?I have a 2021 pk1-5 with high lifter front and rear A arms and a SATV bracket lift with 1.5 spacers on back I have 30 x10x14 carnivores on it now With no problem s can I go up to 32 s or 33 s Has anyone tried this
A true 30" tire will rub on the trails unless you have some kind of mod done. I'd say the largest without any issues is a 28"So the Max size you can go without rubbing? 30" if you go more than that and your at full lock or shocks are compressed the tire will rub the fender. The Offset is the biggest problem. The Rear arms have no offset. they are only the lower arms right?
So if you only have the lower arms on the rear. your limited on the size in the rear not front then.
Like others have side the lift kit makes the P1Ks have a hard ride. ok for roads but i didnt my a Pioneer to street ride.
trails and off-roading & work around the house /fields is why I have mine.
Even with 28" tires you'll feel the power lose. get larger than that you tune it to get the feel of power back. Just like a car you go larger tire you need to lower the gears to get the power / torque back. unless you do motor work. AKA Hess stage 2 kit.
32" tire is roughly 22% larger than stock as your turning alot more mass weight vrs stock.
Best place to seek help for that is in a penal colony. They's got experts. However, you might have luck closer to home, we used to have a glider pilot at Minden who was widely known by the euphemism "Dick Doc" . . . you might be able to guess the lengths he would take it to in order to make his luxurious living.I’m gonna need someone to Splain all that for mawa.
Curious, how do ya fix a broken penal ??
