Tire size vs gear down.
Sheetmetalfab
Sheetmetalfab
2,454
15,683
Alaska
Here’s a Coronavirus quarantine thought.
if I increase tire size exactly the same amount percentage wise as portals gear the thing down.........
shouldn't the dct, speedometer and power be equal to stock?
Reactions: BWAF and Isaiah
906UP
906UP
15,058
143,119
da Yoop
In theory yes but the gearbox (portals) require "X" amount of hp to run due to friction, inertia, etc.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
And heavier tires will also require some HP to rotate the extra mass.
So shoot for a little overcompensation. :)
I would but then you are back to the speed sensors being off a little. Not a big deal if you are off by less than 10%. If you are going to compensate more than that, you will need 2 VS sensor correctors for the DCT and another for the Speedo. And you will lose top speed unless you get a DynoJet PV3 and change those settings too.
DDDonkey
Here you go, the stock tires on a pioneer is 27" bighorns and I put 35" system 3 xrc350 (34.6" true height) with 30% geared portals, so my top speed went from 66mph to 59 mph, I am now under geared. In order to have the DTC be correct I would have to run a 15% reduction and 33" or 30% reduction and 38" tall tires.
Check out the calculator on the SATV website.
SuperATV
SuperATV
1,784
13,119
Madison, IN
www.superatv.com
Dude... Game changer. Go high with the 15% if you're worried about your top speed. Go low with the 30% if you want bottom end power for mud or rock climbing. Either way...its a whole new level.
ShimmeringPleasingBullmastiff small
  • Haha
Reactions: Isaiah
aauman88
aauman88
1,091
2,846
I have 4” 30% portals and run 32” OutBack Max tires. I put the speedo corrector on by 12 o’clock labs and had to set it at +25 to get it correct because I was actually going 30mph when speedo said 40mph. And you only need corrector on rear diff for speedo, the one for DCT isn’t affected because portals are after it. Corrector was $80ish.
Loving my setup now. About to go up to 34 or 35” tires.
D15C0C8D A274 4BC3 9E6B DF216858EFE7 CA633E84 5051 49D1 A115 A5BABC78A5CA 03257DF5 4D5C 47D2 8C17 325CB868B6C6
aauman88
aauman88
1,091
2,846
Ah my apologies, I didn’t realize it was about a Talon. I will see if I can delete
Reactions: Isaiah
DDDonkey
View attachment 198941 View attachment 198942 View attachment 198943
@aauman88
I may need this speedo corrector your talking about, got a link?
Here is mine, just finished pithing the last week 4" portals and 35s. I am under geared just a little, I wish reverse what always geared this way.
Sorry for the derailing of the thread.
IMG 4486 IMG 4510 IMG 4519
aauman88
aauman88
1,091
2,846
Looks great. I want 35’s but I believe true 34 is as big as I can go on rear without scrubbing unless I pony up for the TTC arm setup with rear offset.
Here’s the corrector
Reactions: DDDonkey
U
Ugly
East Tennessee Mudder
387
894
Rocky Top
DDDonkey's explaination is spot on !!!!
U
Ugly
387
894
Rocky Top
DDDonkey's explanation is spot on !!!!
jamesh
jamesh
253
350
DFW
Top speed with portals seems like a bit of an oxymoron.
