P500 Tires / skid Plate recommendations
THeck
87
221
Southeast, KY
  2. Do not currently own
Went on a ride today that was rocky and rough. Hit the bottom several times. Would 26 in bighorn 2.0 give me much lift. I don’t want to go to big if I don’t have too. I found a umhw complete skid for 275. Would it be worth this. Thanks
Backwoods
Backwoods
32,506
333,423
Douglasville ga
I would think so . 26s would help a lot to . When I had a p5 I think the stockers measured about 23 1/2 inches.
Reactions: Isaiah and trigger
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
Anything is better than the factory skids.
Reactions: Isaiah
11,347
84,441
A few nice rock hits, saved the underbelly. Aluminum does bend on a P500 due to distance between frames.
6D6D0F17 C124 4574 9D72 3B422DA6FC41 902A6492 2F1D 43ED BA31 2D5F4C397D32
158,148
You'll never drive over a 5 gal bucket or anything but 26's give it a decent height. Couple of different options on skids, $275 sounds cheap for a full skid, does it cover the rockers too or just what the factory one does? I have Ricochet rock sliders on mine, then I went with a UMHW skid plate. I believe @Mudder did the same but with an aluminum skid.
Reactions: Backwoods
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
$275 seems rather inexpensive to me, who makes them?
158,148
11,347
84,441
Which kind do you have muddier?
Ricochet brand, full center with side rock sliders and all four A arms. For the center I would go UHMW if doing it over again due to the bending of aluminum to where it rubbed an engine mount and rattled. Bent it back with a tractor weight. That said, the Ricochet products are thick.
334F1CE3 0C16 4131 BF6C 4255B43CA037
THeck
87
221
Southeast, KY
Thanksfor the advice. Looks like it’s well protected.
Splorin
299
838
Maine
Side plates are critical if you seriously use it. I was amazed on how much my first SxS (60" wide) bashed the sides regularly. I was usta a lifted , big tire ATV that rubbed occasionally. The narrow P-5 is not nearly as bad but still should be protected.
