P500 To Remove Sway Bar or Not to Remove Sway Bar?
Jetsaround1
Jetsaround1
9
12
I have had several different machines over the year ...the first thing I have done on each one is remove the sway bars ....you can always reinstall them but to get the best of independant suspension they need to be removed.
hallic
hallic
320
1,795
Central MN
Took mine off just before I went out this weekend. Nice improvement on rocky trails, rear end stays planted alot better now.
25yrds
150
370
No brainer
Reactions: J80
J80
J80
36,867
362,201
WNC
With out a doubt remove it. I live in the mountains with a ton of off camber places and to me it has helped keep the rear tires planted to the ground better but I also put 5-2 offset wheels on and 26x11R12 on all four and I know that helps keep it more stable on hill sides too.. I rode with it hooked up but once i took it off it will never be put back on. Now I just need to remove it all cause I did the quick unhook on it and used zip ties to tie up the little bars up that hook to the sway bar.
Mudder
Mudder
NTC/TAP Transition Member
11,726
88,898
I came across my sway bar out in the shed the other day...my first thought was "what is this?"
Same thought for the OEM steering shaft in the garage.
Reactions: futzin
T
timhas2
9
Chico, CA
Hi all which sway bar should I remove the front or the back one?
Reactions: J80
Mudder
Mudder
11,726
88,898
Easy job.
bms
bms
68
138
Pa
So I’m gonna finally disconnect tomorrow or Saturday. What do you zip tie it up to, the small linkage, or something else?
5,541
25,511
Look for interfering suspension parts, on the Talon, just removing one link will have that loose end hitting the upper trailing arm but there are other suspensions with nothing in the way, so just remove one link - not sure on yours.
Tie it up to whatever's there if you have to remove both links.
This shows what I bungee'd to on a Talon and it shows the upper trailing arm that gets in the way (with brake line, lower right).
I 9P5S7w3 L
Reactions: bms
