P1000 Todd's 2018 Build
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
My next project has arrived. Corbin Custom works turn signal kit with horn. Build quality on this harness is damn near OEM. The signal module is potted really nice and the instructions look great. I'm not going to get to it til later this week but it should go on without an issue. Really impressed so far.
IMG 20200601 195441 01
IMG 20200601 200952
IMG 20200601 201001
212,755
View attachment 205707View attachment 205708View attachment 205709
Well hell, that wouldn't help me a bit, I don't know which way i'm going to turn! HA!
  • Haha
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I'm really impressed with this kit. I relocated the front turn signals a bit from the directions but everything went together really well. Overall a great product. I really like the integrated rear signals in the OEM tail lights.
Screenshot 20200603 222032
Screenshot 20200603 222021
ehart814
ehart814
1,701
3,889
NWPA
View attachment 206120View attachment 206121
I'd like to get a signal kit... One less thing for the cops to complain about if I had working signals and used them. I'm a bit intimidated by the install. Did it require a lot of disassembly? Like plastic, etc
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Left front fender flares had to come off to route the wires to the switches and that's it. Easy plug and play. Very good templates for light and switch holes. Easy to install in 2 hours or less.
IMG 20200603 202218
just made my own and while I saved a great deal of money it took more than 2 hours, to solder, heat shrink, and took time to find a good route for everything.
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I could have tried that but I really like that this powers on with the key, plugs into the tail lights with no splicing and the signal module is potted and sealed. I'd have probably spent almost as much money and 10x more time sourcing all the parts myself.
That’s what I meant convenience and ease of install is worth the money. I agree, I’m in the middle of something that gave me an opportunity to rewire a few things since the plastic was removed, one of which being another brand kit that did not have sealed blinker or plug n play connections.
It would have been nice to plug n play everything but it was already cut and soldered in. I really just replaced the front lights and blinker, and relocated the switch.
Reactions: ToddACimer
ehart814
ehart814
1,701
3,889
NWPA
I looked up that kit and it seems to be a pretty reasonable price for the convenience, and the quality as you have described. But, does it have a 4 way function?
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
For some reason I thought the kit did have a 4 way flasher but it turns out that mine does not. It is listed at "available" on their website. I asked what it would take to add.
Reactions: ehart814
Bohnt10
Looks great! Anyone know if there’s a discount code for forum members?
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I talked to the guys at Corbin Custom Works today and bought the 4 way flasher switch and harness
Reactions: ehart814
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
They don't have a discount code and they are having trouble getting OEM Honda connectors sit they have a limited supply of kits available.
JimmyA
JimmyA
1,644
5,504
Northeast texas
The lift is a Wheeltronics 6k. It's Snap-on branded and pretty much awesome. That's probably the only reason I got this much work done in a week and a half.
Anyhow, fully built Pioneer 1000-5, 55 miles, 5 tires, beadlocks wheels, completely built for having fun. Fox Shocks,LED lights, full skid plates, a-arm guards, Alienshade, Terra45 winch, under seat fan, side mirrors, lots of extras For Sale $22,500
View attachment 132967 View attachment 132968 View attachment 132969 View attachment 132970 View attachment 132971
Just kidding, we're gonna send this one but I'd build you another in a heart beat.
What side Mirrors are you using? I can't find a useful mirror for my 700/4!
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Starting on my 1200 mile service (1262)...
IMG 20200626 142201
Whoops... Looks like we need some extra beef up in here. If somebody makes a crossmember that @Plumber32 and I cant smash in 500 miles, that would be 1 tough sum b****
MIG 3” flatbar the entire length of the factory crossmembers. Then get the high strength steel @snuffnwhisky added to his and @joeymt33 machines for additional crossmembers.
Reactions: Plumber32
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
The 2 factory ones look pretty good with the tube gussets on them. I think welding the crossmember at the subtransmission would be stronger but it seems like it would be easier to remove the sub transmission out the bottom and welding the crossmember would probably make that tough
I didn’t weld to frame Only to crossmembers, yes a bolt in would be best by sub trans.
Reactions: Isaiah
Similar threads
Replies
Views
509
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
