P700 Toe out spec's
Lynn
Lynn
263
134
Yakima,WA
Does anyone have the front toe out spec's for a Honda Pioneer 700. I put a Lift kit in mine and just set it to 2 inch lift and it drove horrible in the snow. I see it's toed in now where before it was toed out. I'm guessing maybe 7/16" out should be about right but I can't find spec's anywhere.
68,132
Book says it just like this.
TOE-IN: 0 +- 10mm (0 +- 2/5")
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
What exactly do you mean by "drove horrible?" Maybe others can help you fix the problem.
I set mine as close to zero as I could and it drives great. However, I haven't had it out in the snow.
I agree, could you please provide more info?
Lynn
Lynn
263
134
Yakima,WA
Thanks for the information. It drove searching for a path. It didn't want to go straight down the road but continuously going right then left a constant battle to keep going straight. It drove fine before I added the lift kit. I'm sure the toe in/out changed, I can see it just looking at the front tires in relation to the rears, that it is now toed in quite a bite. I had to adjust my Rubicon also as it broke in and the suspension came down it toed out alot. Setting the toe out fixed it.
Lynn
Lynn
263
134
Yakima,WA
10mm is just over 3/8 of a inch. So i wasn't to far off. So zero + or - 3/8 " Being a former front end alignment guy, when power is on the wheels want to pull inward, so a little toe out will make up for any slack in suspension components. So I'm going to set mine 1/8" to 1/4" toe out.
