Torque Spec for rear Trailing Arms
G
Garyjean
9
10
I recently installed a Rear Hitch, and i am looking for the Factory Torque Spec for the Trailing Arms. I have seen several videos where they state "good and tight", however i would prefer to bring it back to factory torque spec.
Reactions: TxDoc
G
Garyjean
9
10
FYI I contacted Honda Direct, and they are recommending 58 ft/lbs for the Talon X4, this is quite a bit lower than standard torque for that Bolt size
SLOWPOKE693
SLOWPOKE693
1,642
6,299
Somewhere in Texas
Go tighter. Those trailing arm bolts like to wallow out the holes in the frame and when they do its a pain in the azz to fix them. Raceco-USA makes a brace kit specifically to prevent that.
Reactions: CID
5,060
22,702
@Lil_Steve @Boundertom
Reactions: Lil_Steve
5,060
22,702
Those guys both have the wallowed out trailing arm hole problem?
Not that I know of but I've ridden with both of them and wanted them to be aware of the potential problem. 👍
A
adudes
71
176
  1. Talon X4 LV
I looked in the Honda factory service manual, spec is 58 ft/lbs
pete_plp
pete_plp
15
58
USA
  1. Talon X4 LV
Happy Friday! Would you have the link to the manual? Im looking for a few torque specs like break caliper nuts etc. Thanks
I believe he is referring to the rear radius rods, not trailing arms, since he installed a hitch.
But yes, the front trailing arm holes are an issue and the braces Jamie sells are the ticket for preventing it.
Reactions: Remington and CID
A
adudes
71
176
  1. Talon X4 LV
I do not have a link. I bought a paper copy of the manual.
