P1000m3 Tot's Rig
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
The HD3s look good. They were my 2nd choice after the 6s. Hated to spend 330 for something I'm going to scuff up but couldn't find any cheap 14" wheels
Reactions: pct
Tot
Tot
661
462
Des Arc, Arkansas
No idea bout the 6+1. I've always heard the 5+2 was close to stock. My 30s stick out in the front and sling mud everywhere. But mine aren't skinnies either.
I thought I read somewhere that the 6+1 were stock. The fronts will only be 1/2 inch narrower on the front so really 1/4" on each side.
Sent from my SM-G900V using Tapatalk
Reactions: pct
Tot
Tot
661
462
Des Arc, Arkansas
Attempted to paint the letters just now. I used a paint pen and it wasn't looking to good the second time over. I may not have given it enough time to dry. Ae24c19cd251c5ae96746148dd5b0906
Fe6fab260b6e14caf274b9188192b4ba
Reactions: pct
I like the white across the back. I'm wondering if anyone makes a decal yet for that I know they did on the 700
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Maybe that's what it was, heck I can't remember. I suffer from old timers disease lol
Reactions: Tot and sharp
This coming Friday I'll be ordering new wheels for the OL2s. I'm going with HD3s. There is the option for 5+2 and 6+1. My thought was I could but the 6+1 for the front and the 5+2 for the rear and it should give the same stance. Am I wrong? or should I just go with the 5+2 and get 1" spacers for the rear?
I would get the same offset wheels so you can rotate them. The spacers aren't too expensive and seem to hold up to my abuse.
The 5-2 is a little wider in the front and a little more narrow in the back. The 6-1 is real close to stock in the front and a lot skinnier in the back.
Either size would be fine if you get all four the same and use 1" spacers.
Tot
Tot
661
462
Des Arc, Arkansas
I have sometimers. Sometimes my brain works sometimes it doesn't
Tot
Tot
661
462
Des Arc, Arkansas
I won't be able to rotate the tires because they will be skinny/wides.
I got to thinking about it, if I get the 5+2 I can get 1" spacers for the rear and equal out my stance on all 3 sets of my wheels and tires.
ghost
ghost
993
1,874
BC
Tuesday I should be picking up a set of skinny/wide Outlaw 2s. Have a little rock/road rash but for the price I can't beat it View attachment 14127
Would you call the stock p1k "skinny/wide"
Why is the advantage of skinny wide? Just different types of traction front and back I guess. I'm debating a 9" X 11" width setup (Stock) vs 10s all around. Probably going with Evos
Thanks
Reactions: pct
Thanks
What's the best aggressive street tire for the machine
Tot
Tot
661
462
Des Arc, Arkansas
Thanks
I call stock skinny wide. I'm not sure if there is an advantage or not to skinny wides. My truck tires are 9 wides and the Roctane XS are 10s. Both setups feel stable.
The OL2S will be 9.5 x 11
ghost
ghost
993
1,874
BC
Sounds like most folks are going for same size all around so they can rotate.
I wasn't sure if Honda used 9 x 11 for performance reasons or just cause they didn't want a wider machine with bigger tires on the front.
Reactions: dotman1
Tot
Tot
661
462
Des Arc, Arkansas
For the price I'm getting these OL2s I'm not worried about having to rotate. The rear tires have a little rock/road rash but if need be I'll replace the rear with skinnies. For the mud skinnies are a little better because you'll cut through the mud better.
Tot
Tot
661
462
Des Arc, Arkansas
I personally like the same size all around, 1 you can rotate and 2 I like the looks better
Reactions: ghost and Bryan 22
Tot
Tot
661
462
Des Arc, Arkansas
With the help of some of the guys on the Facebook page (join and check it out) I was able to extend all of my hoses this afternoon. Tomorrow I should start working on my snorkel.
Reactions: pct
Tot
Tot
661
462
Des Arc, Arkansas
Just ordered my wheels hopefully they will show up tomorrow like the other ones did
Tot
Tot
661
462
Des Arc, Arkansas
Got the hose today. It wasn't as stiff as I was hoping for, but I think it'll work. I can squeeze it together without a lot of resistance. I'll post some pictures of it after lunch.
Tot
Tot
661
462
Des Arc, Arkansas
Pictures of the stuff I have.
6 feet of hose, 2 elbows, 1 3 inch pcv pipe, silicone, pvc sement, 2 hose clamps, and dielectric grease. Around $30.
1f8a8c694f0f42e913bb5f6db513fc3a
Squeezing the hose
1d46bea1f6529533be9b66f8c848c9d4
9e59629686908855e6b3790ca2b66c14
Similar threads
