P700 Tow points?
03mossy
03mossy
283
1,121
MN
  2. Other Brand
I've had to use my 700 now a few times to pull out my stuck AC atv. I've noticed the 700 is seriously lacking it spots to hook a strap to. I just used the ball on the receiver hitch but after watching that video posted this morning that may not be the best idea. Anyone have any ideas of something I can add to the front and back to give me some solid tow/tie-down points?
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
If you have a winch you can either use your winch or tie to the hook.
There is/was a beefed up trailer hitch available. Maybe someone here can recall the name.
beyond that, you will need to do some custom work. Highlifter has some products but I don't think they are designed to fit the 700. Yet, they might be something you could easily modify to fit.
Hickstrong
Hickstrong
45
37
Pa
the p-700 receiver for the draw bar looks weak and mine is developing cracks. I use wood to heat our house and tow pretty heavy loads of it. Mine survived towing a heavy ranger S X S up a steep hill over the weekend but I need to weld some angle iron on it to make it stronger. This seems to be the only weak link on the machine. I may weld up a plate to attach clevis loops to it not only for recovery but for safety chains on my trailers.
