P1000m3 Tracks
Rockydog
73
165
Canada
Any one know what the outside dimensions of a pioneer 3-1000 with Camoplast tracks on it would be.
Reactions: Lady01 and BWAF
P
patpete
65
149
Alaska
About 72”
C2C9BCC8 EF6F 45B2 8BE3 3C7359B7ED1F
Rockydog
73
165
Canada
That pioneer looks AWESOME!
Looks good. Thanks for the info. What type of tracks are those. And are the rear tracks wider in single width than the front.
Reactions: Lady01
P
patpete
65
149
Alaska
I will have to verify but I believe fronts are 11” and rears are 12”. My 72” is based on rear as it don’t turn and I think is widest point
Reactions: Lady01
P
patpete
65
149
Alaska
Camoplast ts4 tracks , 30” maxxis zilla tires, 2-1/2” highlifter lift, highlifter arched forward a-arms, custom front track mounts, strongmade front bumper, led light bars, boss audio Bluetooth stereo, dual batteries, modified heater with defroster, switch wired in for manual fan control, dual USB ports
Reactions: Lady01
Rustan
Rustan
12
20
Canada
Do the tracks add much height to the pioneer compared to stock tires?
Sent from my Pixel 2 XL using Tapatalk
Reactions: Lady01
Jefferson87
Jefferson87
258
275
Northern California
Your question made me curious so I went and measured mine.
Roughly 16.5" floor to center of drive sprocket.
So you'd think the same clearance as 35s but when you figure a lot of tires don't measure true, then tires squat, especially at 2-3 psi in the snow. They're probably closer to a ~38" tire but you get the gearing of a 14" tire :D
Reactions: Lady01
rickoshea
the utv 4s1 tracks add 7.25 inches per side to your original track,fronts are 12 inches wide,rears are 14,are about 25 inches tall and will add about 425 lbs.to the weight.your height will increase by 5 inches.the r4s are recommended for larger atv's but not for a utv.especially a 1000cc,the sprocket's too small and it's not as robust as the 4s1.and your speed will decrease by about 1/3 with the 4s1 tracks,more with the r4s,15 teeth to the 18 on the 4s1's.those are 4s1's in my avatar.
Test - Grid
