My buggy is a '21 R Live Valve, and I just picked up the Traveler Rock Lights from Tractor Supply.
I've been happy with the Traveler LEDs from TSC in the past, so wanted to give these a go. My question is, if you have Rock Lights on your Talon, where did you mount them? I'm thinking one under each fender...
If you can post some pics of where you mounted your rock lights, that would help. The under fender areas on these buggies are angular and make it sort of difficult to decide where to mount. They require some holes to be drilled, so I want to make sure they are in the right spot to begin with.
Thanks in advance!
Thanks in advance!
