P700 Trail bag(box)
Headhunterf100
Headhunterf100
60
106
Virginia
  2. Do not currently own
What all do you carry in your bag(box) tools, spares, fluids etc. let’s see your setup.
WagginTail
WagginTail
1,564
5,730
SC
Tire plug kit, air compressor, snatch block for winch, zip ties, bungees, ratchet straps, tow strap, shackles, extra lug nuts, tie rod ends, spark plug, assortment of wrenches and sockets, quart of engine oil, hand saw, blue shop rags
42,680
I'm a pack rack, and I put that big bed to good use.
I take a big duffle bag in the bed. In that bag is a designated tool bag...or "break bag", as I call it. Ironic, since this thing never breaks, but...
Tool bag:
Sockets and wrenches of the appropriate size -(8mm, 10, 12, 14, and 17). Make sure the 17 fits in the alloy wheels, if you have them.
Small pipe wrench
Mid size slip joint pliers
A lot of tire plugs and appropriate tool.
A small can of fix-a-flat.
Mechanics wire
Regular wire and some butt connectors
Zip ties
A few hose clamps of various sizes
A few common bolts/nuts
Shoe Goo
Electric and duct tape
1 quart of oil (in ziplock if open)
Known good used plug (in box to prevent damage)
A aftermarket plug cap from a previous repair on my 1st 700.
A small Slime brand compressor.
I'm planning to add a small test light soon.
Inside the duffle bag with the "break bag":
A yank strap/hitch pin
At least one ratchet strap
Bungee cords
*Long sleeve shirt
*Rain poncho
*My lightweight jacket when not in use
*Disposable gloves (makes riding gloves much warmer in a pinch)
Lighter
Food/snacks that don't need ice
A sterno stove and fuel
The rocker switch for my winch (I only have the remote connector permanently installed)
A small shovel/axe/saw kit from amazon
*--when weather conditions dictate them necessary.
I also carry a passenger bag (I'm solo 99% of the time) with:
My asshole/predator repellant
Whatever I'm drinking in a thermos
Ibuprofen
Sun block
Goggles
Toilet paper
Eyeglass wipes
Stand alone deactivated phone with GPS/map app
Go Pro and mounts (rarely used these days)
Phone chargers and charge pack.
SPOT personal satellite tracker
I also carry a 4 gallon Koplin fuel Pak, but only put 2 gallons in it.
And...a cooler. With a big bottle of whiskey, sodas, and water. And food that needs to be cold. And a gallon of sunny delight.
Occasionally, a folding chair.
I'm sure I'm forgetting something...
This sounds like a lot more than it is. Honestly, the passenger bag could be combined with the duffle, but I like having it at hand.
