P1000 Trail spares, what do you carry?
Superthrill
667
1,557
North Carolina
After coming across a Rzr on the trail with a busted tie rod, got to thinking about trail spares for the P1000.
What do you carry? What parts are prone to miss haps on these machines?
Two tie rods and a pair of clamps.
Honda clamp pn: 95018-46250, BAND, AIR CLEANER CONNECTING TUBE (46)
Tierod thread Multi - Field Stripping a Tie Rod
Standard tools, recovery gear.
If it’s a long rough trip far away from truck, we generally have one spare for 2-3 machines and a couple of axles.
Day trip near truck just the tie rods, MAYBE a spare.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
2 tie rods, wrench for removing them, fuses, relays, plug kit, wiring and connectors, tools, air compressor, gas, pump and sprayer, tape, big tie wraps, lug nuts, wheel studs, and a bunch of other odds and ends of stuff.
Boss0144
137
147
Commerce Township, MI
You guys say you carry 2 tie rods - do you carry tie rod ends at all? Or is the tie rod the issue 90% of the time? Thanks!!
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Probably not a bad idea to keep them on hand...but for the.most part the tie rod is the failing point.
Reactions: Plumber32
67,318
No ends.
popeye
popeye
3,273
14,642
kapowsin, Wa
Just the inner tie rod
Boss0144
137
147
Great, thanks. I cut some holes in my doors - now I need to fill them up with stuff!
E
Ericthered
Eric The Red
271
522
Sparks, NV
Last weekend's trip into Northern Nevada ended the day with a stick thru the tread of the tire. I pulled it out, plugged it and stopped for lunch.Looked again and it was already flat. Really happy I put a spare tire rack on driver's side of the bed. Yes it takes up some room, but if the tire had gone flat this fast I would be stopping every 5 minutes to air up. Luckily, put the spare on for rest of trip. Jack, spare tire, cross wrench and tie rods with big wrench, gas, water and a cooler of water, soda and a beer are essential !
