Trailer Hub Bearings
1border4manu
1border4manu
2,167
14,715
Zephyrhills, Florida
How often should I be greasing the bearings on the trailer used to haul Little Red around? I know to much is just as bad as not enough. Thanks for the help.
20190810 120009
Reactions: rtn001 and BWAF
Vikes79
Vikes79
SKOL!
10,869
105,421
South Dakota
Honestly if they aren’t leaking grease I leave them alone.
I try to repack every 3rd year. I know people that do it every year. I also know of trailers that have never seen a grease gun ....ever.
Really depends on the miles.
I give a good violet side to side tire shake every time I hook the trailer. If I sense more play than normal then I’ll dig deeper.
420Rancher
37
84
Innisfil
Also depends if a trailer is used on salt roads. By habit i always stop in the first 20 miles and feel the hubs for heat. Its easy to tell when they are starting to go if you pay attention.
208,011
How often should I be greasing the bearings on the trailer used to haul Little Red around? I know to much is just as bad as not enough. Thanks for the help.View attachment 159587
I couldn't tell, but it looks like you have the bearing buddies hubs caps? That's good! Keep in mind that the seals are designed to keep grease in not water out, never submerge a wheel long enough to launch a boat with a warm wheel, it will vacuum water into the bearings. I've got 16'000 miles on my bearings and going strong. I have a digital thermometer and shoot the wheels, the brake wheels will be a little warmer than the other axel wheels, happy travels!
7,139
27,144
I have some of these in my tow vehicle.everytime I stop for fuel I compair tire and bearing temps.
Screenshot 20191006 203442 Samsung Internet
Very easy to tell if you have a low tire also.
O
oldfortyfive
595
1,316
Illinois
I've been making a 2600 mile and 1200 mile trip every year. I carry a spare hub complete with bearing all greased and read to go just in case. From what I'm seeing cleaning and regreasing every 2-3 years should be about right. My bigger concern is tires. I'm changing tires every other year. (note: aluminum single axle with P500, about a 2000lbs load)
That reminds me... I’ve been running my gashed tire from CO and it’s finally got to the point where the plugs won’t hold air longer than a few minutes. So we took it down to the dock and jumped on the boat yesterday. Had my portable air tank and put some air in the tire and headed back to the shop. I was a couple hundred yards from the shop when it went real flat. It pissed me off so I decided to put the spare on. And OMG... I was amazed at how much tire heat was created in such a short distance.
Tundra20
Tundra20
316
811
Arkansas
U probably good for a while liked someone mentioned before jack it up feel for play in bearing u do want some play but not alot just a little wiggle the 3500 lb axles dont seem to hold up to many miles in my opinion I would chk every 3-4 mos if u pull that trailer alot
Reactions: BWAF
