Has anybody had problems with trans not wanting to shift and slipping when cold. Mine does it even after warmed for 10 min then taking off. But after driving a while it will shift fine.
fishin2Dmax said:I run in colder temps than 20 degrees and I haven't experienced what you describe. I have noticed on very cold morning (8 degrees) the tranny shifted a little strange, but as it warmed up a little, all seemed normal. I'm sure mine was due to the low temp affecting oil viscosity. What you describe (after warm-up), I have not experienced. 20-40 degrees is not cold enough that it should have that much effect? If it were mine, I would have the dealer look at it and make sure the proper oil and viscosity was actually used in the last service? Did it do this before you had the last service?
