Transmission Issue
BrophyCreek
BrophyCreek
489
2,984
New Richmond, WI
Need some help diagnosing this one: 2016 P1K-5 DLX.
Initially died when I pulled up to a stop sign. Didn't want to move. Let is sit, then was able to go about a mile. But then realized it would shift up, not down. So eventually lugged out. Flashed a code, but I can't figure the code out. Two long, four short. So I thought 114 or 11-4 but longs are ten? So 24-0 or 20-4? None of those are on the list for the transmission. After sitting overnight it acts normally. The day before, right before it occurred, I was running hard and fast for a fairly long period. Probably 20 + miles driving it like a rally car. . My initial thought was the clutches over heated. Weather was coolish. 60ish and rain. Anyone know what code that is? Any thoughts on root cause?
Sent from my SM-S911U using Tapatalk
Neohio
Neohio
Beast of the East
14,469
72,343
Painesville Ohio
What part of the dash is flashing the code?
Check engine light?
Gear indicator?
Can you snap a video, upload to youtube and share here?
If gear indicator, go into the site service manual, https://hondasxs.com/threads/honda-sxs-service-manuals-500-700-1000-talon.34567/ and search for DCT codes.
1719315854359
That page # is from a 2017 manual, so it might have changed.
906UP
906UP
14,036
132,605
da Yoop
  3. Talon X
Could it have been a 44-2, that's related to the DCT
DTC 44-2 (EQT SENSOR HIGH
VOLTAGE)
• Before starting the inspection, check for loose or
poor contact of the EQT sensor 2P and PCM 33P
(Gray) connectors, and recheck the OTC.
1. EOT Sensor System Inspection
Check the EQT sensor with the MCS.
Is about 5 Vindicated?
YES - GO TO STEP 2.
NO - Intermittent failure
2. EQT Sensor Inspection
Turn the ignition switch OFF (0).
Disconnect the EOT sensor 2P connector (page 11-
59).
Connect the wire harness side 2P connector [1 ]
terminals with a jumper wire [2].
Connection: Blue/yellow - Green/white
Turn the ignition switch ON (I).
Check the EOT sensor with the MCS.
Is about O Vindicated?
YES - Faulty EOT sensor
NO - GO TO STEP 3.
Neohio
Neohio
Beast of the East
14,469
72,343
Painesville Ohio
The P1K manual I have is 2016-2020 so your info should be good
24 is DCT related as well. If something has failed, it may only auto shift 1 way?
Sounds like it wouldn't downshift when he was coming up to a stop. Maybe check shift motor connections?
His machine has had a rough life since Takeover. Maybe something jarred loose?
113,805
Assume you had the clutch campaign done back then? Not 100% sure with this issue if it has anything to do with it tho?
Just a thought
Reactions: ChadD and TxDoc
DRZRon1
DRZRon1
1,158
3,730
PA
VOIDH on the pioneer rally car wannabeing
Neohio
Neohio
Beast of the East
14,469
72,343
Painesville Ohio
This will cause clutch issues.
FYI, It has a manual tool in the little tool case so you can manually shift it by hand on the engine case.
But I would be no one knows about that.
Can you shift it? Or does it just lock the trans into 2nd gear?
I know of the lock 2nd gear piece, wasn't aware you could shift remotely like the P5.
BrophyCreek
BrophyCreek
489
2,984
New Richmond, WI
Sorry yes, gear indicator is where the code was. Another symptom as I was trying to limp it back to camp was that I would get about a mile depending on the terrain due to up shifting only. It would lug out. Stop, let cool down for 10-15 minutes. If I tried to go too soon, it would start and run normally. If I tried to shift it I to gear, hard clunk and the engine would die. Like dumping the clutch when stopped and in a high gear. Did this P to R and N to H. I ended up getting my truck and winching onto the trailer. Home the next day and have ran up and down the driveway a few times. Shifting is normal. I did get it to normal operating temp, but not hot
BrophyCreek
BrophyCreek
489
2,984
New Richmond, WI
So, she has been running fine since this happened a few weeks ago and I haven't had any time to dig into try to diagnose it. But yesterday it happened again running down to my boat. Same deal. Shifted up in auto but not back down when I came to a stop. Had just a dash on the gear indicator. Was able to roll in N into a parking spot. Took the boat out and a few hours later fired it up when I got back and was able to put it in manual and drive it home. When I first turned on the key and waiting for the fuel pump, it sounded like the shift motor was shifting it back down to 1st while stationary. That sounds like a bad connection/maybe corrosion somewhere /maybe a bad wire?? Took the week off so I'll be digging into it today or tomorrow. Wish me luck on finding something definitive. Intermittent problems suck to troubleshoot.
DRZRon1
DRZRon1
1,158
3,730
PA
check all battery connections\cabling\etc.- these are voltage sensitive
then - inspect neutral switch\wiring and clean\inspect shift motor
Neohio
Neohio
Beast of the East
14,469
72,343
Painesville Ohio
Grab your phone and video the dashes in the gear indicator if/when it happens again. That will point us in the right direction.
Reactions: Rayger143
BrophyCreek
BrophyCreek
489
2,984
New Richmond, WI
Will do. But in the moment I was crossing a busy road, so I'm not positive, but I don't think it flashed the code. Only a steady dash on the gear indicator.
Reactions: 906UP
BrophyCreek
BrophyCreek
489
2,984
New Richmond, WI
This screams shift motor.
The motor itself failing? Up shift but no downshift is a common issue? I had a similar thing years ago on a Foreman. That turned out to be the gear position indicator. I took it apart, cleaned it and regreased. It actually looked pristine, but that solved the issue
Reactions: Rayger143 and 906UP
Similar threads
