P1000 Transmission issues
Hoode_68
7
6
Connersville Indiana
I'm having a transmission problem when I started up on the display on the dash it shows a (_) but it is in park I put it in reverse it still shows a (_) I put it in neutral The dash shows reverse I put it in h it shows it's in neutral I put it in Low it says it's in high The transmission is in the right gears but the display is not reading properly there has to be an electronic sensor in the transmission that tells it what gear it is in for the display
Reactions: CumminsPusher
Reactions: AKRider
Hoode_68
7
6
Yes I know what you're saying. The computer needs to relearn. Try this procedure but again do it in a timely manner it might take two or three times to get it right but do this first.
Hoode_68
7
6
OK I'll try here in a little bit and let you know how it turns out thank you very much for the help
AKRider
AKRider
1,402
3,225
Palmer, Alaska
What CP said. You need to perform the steps very quickly. It took me about 6 times to get it right when I did it.
