Transmission Problems
Bobsagetisgod
29
57
Illinois
Got stuck in the creek today, had a surprise patch of silt suck me in. Anyways the water got up to the seat on the driver side. Once I finally got pulled out, I believe it's my 3 and 5 gears hesitate and rev really high when upshifting to those gears. I'm not all to familiar with this unit, but I remember back with the Suzuki king quad, when we sank them, we'd flip them to drain them, change the oil, and be on our way. I also seem to remember a water drain plug on that four wheeler.
Like I said, I'm not too familiar with this problem, so I drained all the oil, didn't jump out as milky, but I'm hoping for an easy fix with fresh fluids. Anything else I can try? If the clutches are torched, that's fine, I'll take it in, but if it's something easy (like my king quad was), I'll just do what I have to at home. Thanks.
W
wyodlr
147
209
Cody Wyoming
If the water got up to the seat you will have water in the gas tank and sub tranny if the lines aren't extended, check the air filter and ducting to it to make sure you got no water in it. If it shows any water in it Honda will not cover it
If they're slipping in 3&5 reverse and first should be also.. what range and gear were you in when you got stuck? Did you try and drive out first? Sounds like the clutches are toast...
Bobsagetisgod
29
57
Illinois
I was pretty much at a 45* angle to the driver side. Only the driver side got that deep. So I believe the gas tank and air ducting should be fine. I'm not sure about the sun transmission.
That's what I'm figuring. I tried driving out both in low and high. Forward and reverse.
Z
zin01
174
235
Royse City
I don't have any person experience with this but the consensus seems to be that if the oil was very brown you could have smoked the clutch. If/when I'm stuck I go to Low first thing the gears are a little to tall on these things and you need low to try to turn the tires in thick mud. Anyway how did the oil look?
320,457
Like said above I've got a feeling your clutches are spent. Drain all fluids and fill back up see where you're at. Also check air filter and air tube leading to it
Reactions: pct
Bobsagetisgod
29
57
Illinois
The oil looked pretty standard as far "brown-ness," I'm going to pull the pans I drained it into and inspect it under some light after work. It didn't smell burnt or anything though.
10-4 I'll check the air box this afternoon.
Reactions: CumminsPusher
Bobsagetisgod
29
57
Illinois
Does the sub trans use the same oil as the rest of the engine/transmission? Or is that isolated from everything else? I see a separate fill for that under the seat
I believe so, I'm nearly positive it does.
@CumminsPusher and @snuffnwhiskey y'all've had it apart.
320,457
Reactions: pct
Bobsagetisgod
29
57
Illinois
Ok, I'm not going to touch that, my issue isn't the transfer case, it's the clutches. So as long as it's self contained in regards to its oil.
I'm a quart short so I'm at a stand still right now. The drained oil was brown, but not overly brown. It didn't smell burnt, and there was no clutch material to be found. We'll see. I still think it's trashed, but there's always a chance.
pct
pct
Lost in the hills
790
1,023
Letart WV
Let your old oil set in the pan for a while then pour it into another pan when you get close to the bottom of the pan is when you will start seeing clutch material in the oil it will look like sludge if there is a lot take it to your dealer
Jimmy-AZ
135
161
Gold Canyon, AZ
A little update, the R,1,3,5 clutch pack was torched. Repaired and back on the trail.
Good news Bob, did you do the fix yourself? If so, we would like details like which plates were torched, any gear mashing, bearing or shaft replcements etc.
Bobsagetisgod
29
57
Illinois
No sir, it ended up be approved for warranty replacement at the purchasing dealer. My buddy picked it up for me so I didn't get to talk to the guy about anything either.
Side note, the service manager told me that Honda is working on a fix for the clutch issue that should be available within a couple months. What that fix is, he didn't know.
pct
pct
Lost in the hills
790
1,023
Letart WV
Glad you are up and running again
