P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Traveller is sick! I did my normal checks that I do after every ride and found the rear diff oil to be very dark. I have magnets on my drain plugs and there was a lot of fine metal on the plug. This is probably due to the failed pinion seal I had at 700 miles. For now I have flushed the diff with ATF and refilled with new gear oil and 50% Lucas. Hopefully it lives a little longer. It's not louder at all and not rattles yet. I will go ahead and order new bearings and seals to have on hand.
I used a magnetic rod and inserted in to the drain hole and found metal.
This is the fine metal on a magnetic rod.
0a98411e1d6160c4d6107c496211e40b
Seen here is after I cleaned the rod with a rag.
2700791a876fabf4ba556ebbde7d6da6
I was able to get metal out doing this several times. None present after the ATF flush. Glad I was using magnets on the plug!
Btw, both side bearings feel very tight by wiggling the axles. The propeller shaft has a lot more wobble versus the Farm Rig with 300 miles. Still not leaking oil and no sign of water after Saturday's ride which included A LOT of water riding.
DGann
DGann
548
1,575
Russellville Alabama
Poor traveler, its owner must have been mistreating it. Hope you get well soon traveler!!!! Bad owner! Lol
Rambo
Rambo
339
822
Southern Indiana
Good catch, I need to check mine more often. I know I've seen the post on the magnets for the diff plugs awhile back, but would you care to remind me what your using for those. THANKS
Rambo
Rambo
339
822
Southern Indiana
brianmcbride99
O'fallon, MO
Reactions: sharp
Neohio
Neohio
Beast of the East
21,540
91,180
Painesville Ohio
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Ruh roh!
Reactions: sharp and joeymt33
I found one tie rod ball joint nut slightly loose. I’m sure it would’ve got worse if we had wrote a little while longer.
Then the driver side tie rod was loose at the large nut inside the boot.
2e3cf6390781d3fbe3a7570737969de4
No picture of this but I broke another steering stop. That’s the third one I’ve broken, they seem to just shattered into pieces.
The mud buster fender flares were wrinkled a little bit. I was able to straighten those out with a heat gun.
Here’s the before picture, I didn’t take any after pictures
2cd53046ec3c7ddf3cebd63df292b4b8
Also it seems that I damaged some plastic on the passenger side. It looks like a relatively small and easy piece of plastic to replace but I think I’ll leave it for memories.
33346fed009378ad389f664ec50619c6
Similar threads
Hometeam
Replies
Views
2K
Hometeam
