P1000m5 Traveller II
Ac240df1c2fe35d8a8a5be85c6e90f10
39,079
I got time for a couple more before I go play in the rain.
Here is the interior lights.
2f617e2d8e9dc905ee7ca2d4a92106aa
95d7af9b92e67e57ac2e0031d297def5
Reactions: Dp5hunter
Marine660
246
244
Slight change of topic, what did you use and how did you paint the gear label selectors white? Any scuffing required? Did you mask it off? What paint did you use, and how did you apply it? THANK YOU
Here is the mock up for the switches and stereo. I say mock up because I'll use textured plastic for the finished product.
0efbeee32d28ab35a82f2e53485f2d75
39,079
I just used "white out". No scuffing. No masking. Just went slow and brushed it on.
It seems to flake off easily if wiped hard. It's not a problem for me as I kept the bottle of white out in the glove box.
Reactions: JTH
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
I would test it on a sample piece first but maybe if your wife had some clear fingernail polish.....
39,079
Maybe white finger nail polish...
Marine660
246
244
Walmart sells glow in the dark white paint. I am going to try this out! Maybe they will glow some at night so they are visible.
Reactions: JTH and JACKAL
39,079
I got this thing called a job which has been keeping me from wrenching on the new Pioneer. Oh well, I guess I should keep the job or no Pioneer at all! Recently, I had time to get a couple little things done.
Here a couple pics with the light cubes wired up.
For comparison, here is stock LED head lights.
87cc73acafb58e71b64523a9017fc5fe
Now here is the two light cubes on with the headlights.
Ce7f9dab5c14d21dfa3308909f2fdeb0
265,332
Very Nice! @joeymt33
39,079
The magnet is rated for 25 lbs. I ended up using two.
39,079
I got around to installing the extra battery and isolator. I want to thank those that have gone before and made this mod easy to pick parts and install.
269dd8aa5a91545f92fa770ff46046fb
Here you can see the battery hold down and the isolator mounted behind the battery.
3550efb63eb4f399b9734a7866903d26
265,332
@joeymt33 Very nice, like how you have the isolator tucked away while integrating a battery strap and ground for the second battery. But what is the black box between the radiator tank and the intake pre filter cover? Is that your PDM or winch relay?
39,079
In my opinion, the MudBuster fender flares for the P1000 is lacking a little bit. They do offer much better protection but they could be almost perfect with a little modification. They also have clear instructions with pictures and provide plenty of hardware. I'll explain with some pictures.
In this picture you can see the front flares taper in toward the front. It looks good and I'm sure it keeps them from getting broken.
27fbaa847d6ca749a87f0a25ac5c9576
Here is a picture of the water spray that I believe could be prevented if the front fender coverage extends a little more.
365613ef5eea090185bb4bc2a350fbe9
Also, the rear fender flares had to be cut to fit. The following pictures shows the problem area.
687874a67b25a9e150d88dad12ab6d60
You can see the rough edge where I cut to clear the frame gusset/bracket.
D51d789a7f8d5793d2bfd0c1ef353ca6
Similar threads
Hometeam
Replies
Views
1K
Hometeam
