P1000 Tried and true cab heat fixes-2018
michdave
michdave
78
195
Maryland
The LE = Limited Edition
There’s a few different “trim” packages for the Honda Pioneer; Base model, Deluxe, and the LE. Honda’s site explains the differences.
But, I’m pretty sure that is emissions equipment and you’ve got a California model.
Did you by-chance purchase it from Owens Motorsports? I know when I was shopping around, they had great prices because they were a high volume dealer but they pulled machine from everywhere to get as many in-stock as they could...sometimes those were machine stickered for California.
I’m sure there is a way to remove it, but I couldn’t tell you exactly what needs to be done. Hopefully there’s some folks on the forum who have done it and can assist. Give the search feature a shot... I’d try searching “California” or “green sticker” or “emissions” and that hopefully will yield some results.
Reactions: TripleB
T
tzink
14
10
indiana
YUP I got it from Owens in Charlston! And it's a deluxe. I found it on parszilla that it is an evap canister. I am going to try unhooking it and plugging the lines. Thanks for the help
Reactions: michdave
Justinp1-5
Justinp1-5
56
70
Central florida
So I got the seat problem solved, but I'm thinking more insulation is gonna cool better, thinking about insulating the compartment behind my legs next. I have sealed all the holes in the floorboard, no no more foot heater, every time I get a heat problem solved I find another. I ride mostly deep water and dont think an electric fan will last. I took the rubber from behind my shifter and made a block for the shifters that works a little better, plan on finding a better fix in the near future. Still have to take out rear floor and insulate it, but it's off to a pretty good start. Any ideas I am open to suggestions
20200802 083512 20200802 083525 20200802 193411
Reactions: JenElio and TripleB
JenElio
JenElio
75,056
677,153
Loxahatchee, florida
View attachment 216394 View attachment 216395 View attachment 216397
What r u using to glue down the insulation? I need to do that soon but im afraid get'n wet often it might come off if glued
Justinp1-5
Justinp1-5
56
70
Central florida
I used spray glue and foil tape, I do hvac so that's what I had. We will c howitt turns out, but doesnt look like itll go anywhere. Only used glue on the back plastic
bulpitt62b
bulpitt62b
27
Illinois
tzink,
Any luck unhooking the evap canister? I just bought the same model from BIG St. Charles in Missouri and mine must be a California model as well. It has the same part as yours in the pic.
Reactions: Isaiah
T
tzink
14
10
indiana
tzink,
Yeah I unhooked it and plugged the two lines running to the motor. And the other line is a vent for the gas tank I am assuming, that one I extended up to the top of the roll bar. No check engine lights so far.
A
AZdonW
76
151
Arizona
Still no issues with plugging that canister lines? Any other differences you've discovered about California version? I just discovered that the model I just bought here in Arizona is a California version!
Reactions: Isaiah
PatioDaddyo58
PatioDaddyo58
48
95
Abilene, TX
Okay guys.. I've read all the threads I can find on removing heat from the cab in the summer, and taking advantage of it in the winter. While my '18 has the "kit" from the factory, it still kinda sucks. After a 20-30 minute ride, the lower back and bottom of the seat is getting pretty warm.
The Pioneer 1K has been out there for awhile now, so I think it's time to make one thread that has all the successful ideas in one place.
Common sense says windshields and enclosures make the situation worse, we know that.
I'm going to put a fan in mine, but I want to use the right fan, the placement, to duct or not to duct etc.. the FIRST time.
Which fans are working the best?
Placement; how close to the exhaust? Correct aiming?
Might end up being a candidate for a sticky too.
Post up! Myself, and future Pioneer owners thank you in advance! :)
Last weekend I raised the bed and removed the plastic engine cover. It made a world of difference. This was a few months after installing a $100+ pre - cut heat shield / insulation kit that 's supposed to be all the rage. It was a waste of money as far as I'm concerned. And removing the cover makes a very noticeable reduction in noise as well. I'll probably put the cover back on this winter and remove the little access cover under the dash to stay warm in woods.
208,729
I agree! Fan is the only way to go.
Reactions: Isaiah
Jwpmel
5
Conway
I have 2 12" automotive fans on my 1005. The one in the front pushes and the one in the rear pulls. No heat issues what so ever. Fans cost $60 on Amazon, relay from LPS for $8.50, 10' outdoor 12 gauge wire and some connectors. Oh, and Zip ties. It was easy and only took about 2 hours.
chipolariverman
chipolariverman
67
Malone, FL
@Jwpmel you got some photos of your setup?
Reactions: Isaiah and TripleB
T
tzink
14
10
indiana
No issues so far I don’t have another one to compare it to so I’m not really sure what the differences are
Reactions: Isaiah
F
FoNugget
Saltillo, MS
you like the 7" fan better than a pair of 4" bilge fans? what did you get, and how did you mount it?
Oh... and didn't I see a post from you about a couple computer fans to push warm air into the cab in the winter? How did that work out?
Where exactly did you mount the fan and did it help with the back seat heat?
