P1000 Turf Mode Question-Updated
Riceman-Ducker
9
34
Central Illinois
Hi folks,
New to the board, so I adjusted the Turf Mode / 2WD LOCK per the instructions and it works perfectly now, as someone mentioned the tech instruction settings are a great starting point, however I did need to do some fine tuning with the center cable position.
My question: When in Turf mode and the rear passenger tire spins, does the driver side than engage (limited slip). I just want some peace of mind that this issue is resolved.
Now the AWD not engaging is a whole other animal........
Thank you in advance.
Again thank you for the info.
My front diff would not stay engaged unless I held the lever up, once I let it drop into the slot it would disengage.
I adjusted that today per a thread I found on here and now it all works perfectly, the front diff adjustment is about as easy as the rear.
Sadly the dealer called today and there is a new recall for the sub tran that requires I bring in it and they drop the oil and stick a camera in to ensure a collar was installed.
Reactions: JenElio and Isaiah
HappyCamper
59
103
Wyo
True, you could actually be stuck if your drivers side wheel was stuck or blocked by an object and the other side just spins. Then you'd have to switch to two wheel lock or 4 wheel mode to get moving again.
Reactions: Rick53 and Isaiah
