P500 U-Bolt Size
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Looking to order some U-bolts to fit the P500 tubing. Specifically for mounting some front fender flares. I get a 1.640" OD on the tube with my calipers. Does 1 5/8" ID (1.625") fit these tubes? or do you need to go to 1.75" and use some thin rubber tubing, etc?
Chooglin
I would say they will work just fine............a u-bolt does not have a tight tolerance! !
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
Take the calipers with you to the hardware store. Then tell us what size u-bolt to buy because we don't have calipers. (BIG GRIN)
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Not sure if my local carries that size and was looking for possible SS or galv ones. Thought someone might have already tried it.
While not for the purpose I had in mind, these might have other uses on the P500: McMaster-Carr
iowaguy
iowaguy
624
1,425
Eastern Iowa
Look at @solrus p500 thread he just put them on his and they look nice.He would be able to tell you what size.looks like he used 5/16x1 3/4x3.
