68"X40" Heat Insulation Deadening Material Mat For Car Trunk Floor Firewall Roof. i orderd mine off ebay.its sticky on one side stuck it to the bottom under side of the bench seat
No experience with those but I can tell you the attwood is pretty quiet. With engine running it's barely audible.Are those shurflo fans quiet?
Sent from my SCH-I545PP using Tapatalk
I didn't use my decibel app but I can say for sure it isn't any louder with the vents. I can't tell a difference in sound at all. Hoping I can tell a temp difference on Wednesday. Going back to mtn with DrFubar to try them out.Will you be able to hear more engine noise with these vents installed? I would think so. @Delton, can you take some DB readings before and after?
Looks good @Delton! Do you mind sharing a picture of the engine compartment view? ThanksI didn't use my decibel app but I can say for sure it isn't any louder with the vents. I can't tell a difference in sound at all. Hoping I can tell a temp difference on Wednesday. Going back to mtn with DrFubar to try them out.
I ordered black 2" ones in plastic and metal. The metal ones are brown lol. They need to pay more attention.I ordered 2" black plastic vents from vent masters. They sent me a pack of 1.5" and a pack of 1". I guess they got confused. I went ahead and put in 5 of the 1.5". I can always swap them out by cutting bigger holes if I think I need more air I guess.
Sorry it's not very clear. I can try again tomorrow in the daylight.Looks good @Delton! Do you mind sharing a picture of the engine compartment view? Thanks
That would look awesome man!I like the look with vents! Looks clean! But I'm thinking paint them Honda Red , and backlight with red LEDs
Vents might be more useful in winter. Maybe use flexible ducting to point it at the windsheild for defrost. Then stick it down your shirt to keep warm.I'm beginning to wonder if vents are even necessary. Water will get through the vents and I don't have a problem with debris inside the cab. Having open holes would certainly flow more air. What's y'all's opinion on it?
I agree.Vents might be more useful in winter. Maybe use flexible ducting to point it at the windsheild for defrost. Then stick it down your shirt to keep warm.
I like the round one in the middle. Just turn it and get airflow wherever you want. Great idea!View attachment 20751
This maybe an option as well for direction of air flow when used as a heater. Just looked up ac car vents. There are all kinds of shapes and sizes.
I got the 4 inch blower works great ! I bought 2 thinking both would fit could only get one in it does the job really well. The 4 inch is more CFM`s.I have two 3" blowers but one 4" will do just as well. Go to Amazon.com and search for attwood 3 inch bilge blower. I got both of mine for less than 34 bucks.
