P1000 Vents for bilge fans
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Will you be able to hear more engine noise with these vents installed? I would think so. @Delton, can you take some DB readings before and after?
If I had something to read it with I could.
I use an APP on my phone. Do you have one available? They're probably not very accurate, but it will still give you a difference before and after even if it's not calibrated to what is true.
872493e1f1477be99069b024e64e2798
34ed1d156c4efcd6ab7e182c70af4208
Just a couple screen shots of what's available on the App Store.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I should've known "there's an app for that" lol. I'll get one and compare
Reactions: joeymt33
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Just ordered 6 aluminum ones. I'll find something to do with the plastic ones. My daughter likes to swing her legs sometimes and would probably smash the plastics lol. Thanks for the help! I may upgrade my blowers to 4" instead of the 3s too. I noticed at higher speeds on the road, the blowers don't do as good of a job. I'll wait to see how vents do first though.
I know someone who might like to have 2 of your extras... ;)
Reactions: Delton
ghost
ghost
993
1,873
BC
Wow - a $10 heater for winter !
Guess I don't need to save up for the Honda Heater. (not that I was).
It would be interesting to see some actual temp readings before and after the vent instal.
If this all works I'm gonna use a three way switch on the dash. Switch up = heater. Middle = off. Down = cool.
jasontjames
jasontjames
146
174
Melissa, TX
I think I am going to make a trip to the hardware store today to see if I can find these local. Just got to remember to keep the socket extensions away from the bumper on this one.....
Reactions: JACKAL
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'll try and do a comparison. Will be riding tomorrow so I'll take baseline readings with just the blower and shielding. Then I'll take readings after the vents are installed.
Markis02
12
Pennsylvania
What fans are you guys using, and where did you get them? Thank you in advance.
Sent from my SCH-I545PP using Tapatalk
vince
vince
155
293
vidor texas
im usin
Shurflo 277-4110 4" Yellow Tail Blower about 30$ off ebay
Markis02
12
Pennsylvania
Do you need 2 under the seat or will one work?
vince
vince
155
293
vidor texas
one should work i think.But i over kill everything. lol
Markis02
12
Pennsylvania
Yea. I usually do too. I'm going on a my second atv poker run this month and would really like to keep my but cool this next one!
vince
vince
155
293
vidor texas
it helped at least 40% heat shiled add took care of about 20% more.
Markis02
12
Pennsylvania
Like header wrap on exhaust?
vince
vince
155
293
vidor texas
no a piece of like fire wall insulation. the roll stuff like at lowes foil on the one side
vince
vince
155
293
vidor texas
68"X40" Heat Insulation Deadening Material Mat For Car Trunk Floor Firewall Roof. i orderd mine off ebay.its sticky on one side stuck it to the bottom under side of the bench seat
Reactions: Remington
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I have two 3" blowers but one 4" will do just as well. Go to Amazon.com and search for attwood 3 inch bilge blower. I got both of mine for less than 34 bucks.
Amre2me2
Amre2me2
381
1,423
Colorado
Is there a fan motor out there that a guy could wire up that would blow one direction then switch directions and blow the other direction with the flip of a switch? This would eliminate the need to flip your motor around in winter. I hunt lions all winter so I like the idea of a heater! Great mod!
I'm thinking you would want to block off these vents in the summer. Maybe a piece of that aluminum backed insulation that everyone used under the seat stuck to the inside of each vent. Easy to remove to get ready for each winter.
Reactions: joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
The plastic ones showed up yesterday but haven't heard anything about the aluminum ones. I'm gonna check my PayPal to see if they took my money. Btw, the plastic ones are very sturdy. I may just use them if something went wrong with the order for metal ones.
Reactions: PioneerPete
