Viair 88P Portable Air Compressor
66,870
The VIAIR 88P is an excellent addition to your Honda Side by Side. With its powerful 12-volt motor, this air compressor can quickly and easily inflate your vehicle's tires, making it the perfect companion for any off-road adventure.
Whether you're exploring rugged terrain or cruising on smooth trails, having properly inflated tires is essential for maintaining control and avoiding damage to your Honda Side by Side. The VIAIR 88P makes it easy to keep your tires at the optimal pressure, giving you peace of mind and a smoother ride.
This compact and portable air compressor is also easy to store and transport, so you can take it with you wherever you go. Its sturdy construction and durable materials ensure that it will withstand the rigors of off-road use and provide reliable performance for years to come.
Overall, the VIAIR 88P is a must-have for any Honda Side by Side owner who values safety, performance, and convenience. Order yours today and experience the benefits for yourself!
71k2NYn1IPL AC SL1500
Russ989
Russ989
22,642
147,257
Those are pretty good, got us out of this jam at the TO a few years ago.
IMG 0037
Scoop
Scoop
5,144
20,334
  3. Talon R LV
Mine was delivered earlier today. It's got a little heft to it, but @Hondasxs used his to add some air to my RR tire this past weekend and it appeared to be a solid unit, so I ordered one.
66,870
This is one of the few pumps that I have had luck busting a bead back on. The small slime pumps will not work at all for that.
Plus this one is super fast.
One downside tho, they recommend hooking it directly to the battery for best performance.
TripleB
TripleB
15,251
136,234
Caryville, Tennessee
You popped my tire back on the wheel twice that weekend I tore up all my junk. I still ain't bought one. I'm still carrying my junk pump and a can of ether.
