P500 Warn Plow Set-Up
bms
bms
66
135
Pa
Hello,
I am looking at the following plow set-up for my 2017 P500. I decided to go with a front mount set up so I don't lose any ground clearance. Here's the items:
  • Warn 893730 Mount
  • Warn 92100 Plow Base/Push Tube Assembly
  • Warn 78960 60" Plow Blade
Not sure if anyone can answer these questions, but here we go:
  • Will this plow set up work with the Honda OEM front bumper installed?
  • Does the mount require drilling of the frame?
  • Does the blade include springs?
I would appreciate any help or recommendations from anyone with knowledge of this set up.
Thank you!
Reactions: rtn001
ALM76
ALM76
L-I-V-I-N
70
241
Lancaster, Ohio
Hey bms, I have the Warn Plow and really like it.
-yes, it mounts to the vertical bars behind skid plate and re-uses the lower bolt. you can leave it on, for any trail riding, as it is up out of the way also.
-no drilling
-blade comes with springs
hope this helps.
Reactions: rtn001
monaco
monaco
374
971
Indiana
bit.ly
-no drilling
hope this helps.
Could you use it to push gravel?
bms
bms
66
135
Pa
-no drilling
hope this helps.
Thanks for that info. Where did you purchase? RMATV has the kit, but it's $100 less on Amazon.
Reactions: rtn001 and ALM76
monaco
monaco
374
971
Indiana
bit.ly
it's pretty stout set up. I've pushed gravel to level the driveway with no problem.
Thanks - that's the kind of thing I've wanted to do but was unsure of how stout these were. I know the P500 has the guts for it
Reactions: ALM76
bms
bms
66
135
Pa
Can you provide the link to the kit on Amazon?
Thanks
It’s not really kit on Amazon.
Search:
WARN 15-20 Honda PIONEER500 Front Plow Mount Kit
Then on that page there’s a “buy all 3” option.
Reactions: rtn001
T
Tstover
141
398
Central PA
Search:
Ok, so I did that, and this is what I got:
98960 Plow, 92100 base/push tube, and the Pioneer 15-20 mount.
Sound right?
Reactions: rtn001
bms
bms
66
135
Pa
One last question...Will this set up work with the Honda OEM front bumper installed?
Reactions: rtn001
MarlinWalker
MarlinWalker
57
170
I don't have it but am looking into it seriously. Here is a picture that was posted in the mount's Amazon review. Looks like the front bumper can stay on.
Warn mount
bms
bms
66
135
Pa
Sound right?
The mount & base/push tube look correct, but my blade is 78960 (60")
Reactions: rtn001
bms
bms
66
135
Pa
Just spoke to Warn. They don't know if the Pioneer 15-20 mount will work with the front bumper installed. He recommended only buying the mount to see if it fits before getting the base/push tube assembly & the blade. He emailed me the installation instructions, which are also unclear as to the compatibility with the front bumper.
Reactions: rtn001
bms
bms
66
135
Pa
Warn suggested I order the mount first and be sure it will work with the bumper. Waiting for it to arrive...
harleyjohn45
harleyjohn45
48
60
Alto, NM
Light work would be ok. My springs set in the strongest setting wanted to trip very easily. A suggestion from a forum member was to add a couple tied down straps "the ratchet type" and that worked pretty good. You would also need to move your driveway skids up out of the way. There are 3 position settings on the blade angle, I'm in the most aggressive, may go back to regular.
bms
bms
66
135
Pa
Mount came, but you need everything in order to install according to instructions (you’re supposed to put everything together, then tighten all bolts).
Push tubes ordered yesterday and blade ordered this morning, but the blade won’t arrive until 12/11, so I guess I’ll still be snow blowing Monday here in PA. Don’t know why I waited!
ALM76, was it an easy install?
RumpRocket
189
295
USA
I still use the snowblower at my place....the dog likes to do it duty way in the back yard so I snow-blow a couple of trails for her to use, I also use it for light clean-up.
Reactions: rtn001
harleyjohn45
harleyjohn45
48
60
Alto, NM
The mount is the hardest to install. Is your winch already there and mounted? The mount goes behind the winch, I had to actually take the winch loose to get the mount in place. That job took me 4 or 5 hours. The instructions are basically worthless, when I would get stuck, I would call Warn and they are great, very patient. Get the mount installed and tightened down it will not cause you a problem. The push tubes and the blade are the easiest to install. Set the springs in the strongest setting. There are three blade settings (least aggressive, standard and most aggressive) I set the blade in the middle position, but changed it to most aggressive to push a little gravel. Not great on gravel, but better than a rake. When pushing anything keep an eye on the blade it will trip fast and i bent the top of my blade a little. I had to straighten it back. It was not designed to push gravel, that's why I used the tie downs to firm up the blade.
We got a light 3" snow here in Alto, NM so I was able to try it out a little and I was happy. This plow will do a great job with a big snow.
Reactions: rtn001
bms
bms
66
135
Pa
My son and I got the mount installed yesterday - it was tough because we couldn't get the bottom bolts lined up, but eventually got it done. Thankfully, I did not have to loosen or remove the winch. Push tubes coming tomorrow.
Yes I spoke to Warn a few times, and they were very helpful and nice to deal with.
What is the purpose of flattening one end and pounding the sleeves into the push tubes?
Reactions: rtn001
