P500 Warn snow plow, should I add a Pulley?
Tom_C
Tom_C
158
473
Virginia, USA
Still working through cleaning up a 2015 500 I purchased, and have gotten the full front bumper, winch mount, new synch rope, Hawse fairlead, etc. I mounted the snow blade on it to test, and it seems to 'pinch' the rope. May be hard to see in these pics, but I'm curious how others do their plow mounts. Can I or should I add some sort of pully at the low "fulcrum' point.... (not sure that's the correct term, but the thingy at the bottom of the blade what guides the rope)?
Winch1
Winch2
Winch3
Winch4
Tom_C
Tom_C
158
473
Virginia, USA
This could be a 'duh' moment. I put the rope inside the pin clamp on the bottom 'fulcrum' point. That might solve my problem.
What say you?
Winch5
Winch6
Winch7
Reactions: toddvdh and trigger
rickoshea
i'd lose the hawse and go with a plow fairlead.i have the plow push frame extender for plowing with tracks so it's not an issue for me,but i would definitely go with a plow fairlead if mine loooked like yours.
hallic
hallic
320
1,795
Central MN
I had a warn provantage plow on my 4wheeler before I sold it, you got it hooked up wrong dude. Using this pic here, your cable comes down off the winch, thru the plastic "pully" from the top plow-side, and straight back and then the winch line hook clamps onto that loop hole thingy in the bottom left of this pic.
Lemme know if them's too technical wordage there, and I can try an draw up a pic or something, lol. Sorry, it's late, and I'm tired.
Also, I'd suggest getting or making a plow strap. Can DIY with 10' of old seatbelt and a connector end, or buy a cheap tow strap or whatever for $5 or $10. It's easy to swap out, and cheaper than breaking a synthetic winch line. Little duct tape to hold the first wrap on, and spool it up easy-peasy. I folded the plow strap in half to fit into the plastic "pully" bit there on the plow, used it for years.
G
GreatNorth
54
84
Canada
I agree that doesn’t look hooked up right.
I found hawse fairlead wore bottom edge and broke under pressure. It’ll last a while, but repetitive lifting out of heavy snow is hard on the bottom edge. I replaced it with a roller fairlead which holds up great plowing. Synthetic rope lasts a long time but does eventually wear out on the most used section while plowing. I only lost ~2’ retying it when it broke which didn’t even happen once a season. It was used to plow a 1 km long driveway in a climate with 2-4’/season accumulated snowpack (actual snowfall considerably higher).
Reactions: Tom_C
hallic
hallic
320
1,795
Central MN
Old crappy pic from when I had steel cable on, but you can kinda see how it routes. You pull the cotter pin out, swing the plasticy pully bit out, slip the cable line in the middle somewheres, swing it back into place, and pop the cotter pin back in. Connect the winch hook to that hole in the back.
IMG 20180301 215918
Reactions: Tom_C
Tom_C
Tom_C
158
473
Virginia, USA
Ah Ha. Thanks for that. The previous owner showed me the method I used, and I'm not surprised it's wrong. ;)
I'll look into the tow strap and plow fairlead, too. Thanks all.
Reactions: GreatNorth
NTC/TAP Transition Member
11,884
90,601
Kinda off topic, but a fun project with an old atv I made a bucket to mount on the plow bars, Could lift and dump. I haven’t fooled with it for the SxS as I now have a tractor. Just an idea to share.
1C5B26EF 7DA9 41CE 93ED 6F3C9656AA6304F2640F 538E 450C 9C44 1EE30FE12050
Tom_C
Tom_C
158
473
Virginia, USA
On an old atv, I made a bucket to mount on the plow bars, Could lift and dump. I haven’t fooled with it for the SxS as I now have a tractor. Just an idea to share.
View attachment 291276View attachment 291277
Interesting. I can't fabricate that without investing in equipment and supplies so I'm not going there, but would be interested in it.
After buying the SxS I'm on the fence if I need a tractor. I have a groundhog max disc still in the box to do soil prep for gardens and beds, which may do for a tractor tiller, not sure yet. I would need a bush hog, but a pull behind might do, again, not sure. I love toys, but another 20+ grand for a tractor and equipment may not be wise since it will all get limited use.
But, back to the topic. I repositioned the cable, much better. I ordered a plow fairlead, and I found a strap from an old ratchet strap I can use. Will post pics once I make the swap.
E
Eeluk
12
Let's see those photos!
Reactions: Buggyman
john790
399
1,155
Clinton ohio 44216
If i were you i would add a pulley.# 1 reason it slows the plow down about 1/2 speed.I have a gravel drive and straight from the winch to the plow a bump of the winch =2 inch movement of the plow.With a pulley a bump of the winch =1 inch of movement it helps me if i hear gravel i bump it and it goes away.Helps in the spring.After the base is frozen it doesnt matter
Reactions: Dave75
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
I added a pulley and connect the hook on the steel line to a short strap with metal ends wrapped around the top of the bumper.
Basic mechanics, 1/2 the speed snd 2x the lift. It makes my plow less ‘jerky’ when I’m raising ir lowering it.
I bought the 18” straps on Amazon.
Here’s some pictures.
8b935fe42499984b97c78394eaec2eff
Ca80b2788ea28413ae768f4eebbd9eef
I put washers on shaft on both sides to keep pully verticle.
4a40ffa75ec57502f4d4f4eb638613a8
