P1000 Water
RampageRhino
RampageRhino
99
263
Pressure wash my machine today and got some water in the intake what's the easiest way to get the water out of there
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
I would say move the air filter and blow compressed air back towards the front. Seal off around your air nozzle with a rag. Blow it out real good.
Reactions: BWAF
Eltobgi
Eltobgi
4,599
15,186
North Dakota
@Mudd_Man has a video of adding a drain plug to a 1000 which shows where the water would accumulate!
But If I had let’s just say a gallon of water sitting in the intake tubes I would take a shop vac and section of small rubber flexible hose, plugging the gap around the shop vac hose and rubber hose to avoid loosing suction, and vacuum it out!
Neohio
Neohio
Beast of the East
14,587
73,832
Painesville Ohio
I doubt compressed air would work, you need something with volume vs pressure. If you have a leaf blower, i would suggest using it from the engine side of the tract, blow it back thru the hood.
Reactions: JACKAL and Hondasxs
Drains the best way. I never had any in mine but I watched @Mudd_Man videos. Shopvac or leaf blower don’t have near the volume to get it ALL, you’ll probably spend more time getting a good seal to get some than just crawling under and creating a drain hole. Water is too dense of a fluid for it to all make the lift on either end of the intake tract.
That’s cool, is it above the stock skid or can it be accessed without removing the skid. And how would one know there was water in the intake before it was sucked into the motor???
Reactions: RampageRhino
CPope
CPope
352
1,152
Pulaski TN
6A8D5188 D7BC 4C54 BC5B 37C794742BAC
194795EE DF79 4BE8 A01C A124528D429D
You are going to have to take the rubber coupling off under the seat right where the intake tube makes kinda like a p trap and remove all the water, we had to do this on the trail for my buddy’s rig at the takeover. Winched the front in the air to let most water drain to this location. About a 30 minute job.
322,690
Like was mentioned a drain at the bottom is the best route.
Imho if it was just a little water it’s really no big deal. Water evaporates especially with air movement. It has to be pulled a long ways up to even get into the filter and the air movement wouldn’t bring a little bit it takes quite a bit to fill up and to be sucked in. The only real other possibility is climbing a really steep hill. If it was an ounce or so from simply washing it don’t be alarmed.
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Water is horse power in diesel .
RampageRhino
RampageRhino
99
263
Thanks for the info. It wasn't from washing it. It had a loose clamp on the very bottom hoses. Water didn't make it to the eng. But the air filter was wet. Tore it all apart and tighted all the clamps down. Going to wash the eng. down to make it look new again till the next ride lol.
20180429 165959
322,690
If the filter was wet make sure to change oil as well.
RampageRhino
RampageRhino
99
263
Oil filters and air filter and oil will be here today ordered it last week because it' do a service check the dipstick the oil looked fine wasn't milky looking. I think I just got lucky with it. I think it happened from the Takeover
Reactions: Eltobgi and BWAF
T
tbaker
365
637
NW. Georgia
RampageRhino was the loose clamp under the floorboard or at the bottom of the air filter housing in front of the bed is that a solid hose or is it in sections with different clamps
Reactions: BWAF
RampageRhino
RampageRhino
99
263
It was the first clamp at the bottom of the floor board as it starts up towards the back of the air box
