Watering dusty riding track
11,313
84,047
anyone have experience/ideas for a water tank set up for dust control of a riding track? Have a track around 4 acres. Water source from creek at a 12 ft pumping head, and have many blue 50 gal. barrels with bung holes. Thinking of a small gas pump, and pvc valve and gravity drip piping, tractor front end loader to carry barrel, or trailer for multiple barrels.
Tractor supply has a PTO driven pump and all the fittings and sprayer heads to make a sprayer you could Put 2 barrels on the 3point and run the sprayer behind before it was too heavy for a small Tractor.
11,313
84,047
Thanks, didn’t think of PTO option.
Reactions: sharp
Firemedic530
Firemedic530
386
1,122
West Jefferson, Ohio
It takes a lot more water than you think. I've had several tracks at my house covering about the same 4acres. I would have to dump 3,000 gallons plus for the dirtbikes to be dust free for about an hour. Less time if we had 4 or more bikes. Atv's or sxs dry it out much quicker.
The best setup I had was with a 2 acre track and old golf course sprinklers. I would run my 2" water pump for 2 hours the night before and then another hour before anyone showed up. That would get us a couple hours. FWIW.
Much better idea
Reactions: Mudder and sharp
11,313
84,047
Darn, sounds like dust mask is cheaper, or learn a rain dance. LOL. Forum always has good info. Thanks.
11,313
84,047
As a start, 275 gallon water tote for the utility trailer with plans for a pvc header boom, fill via creek with 2 inch gas pump. If nothing else, will have a fire pump skid set-up for burn pile safety and equipment wash down. Still looking at fixed sprinkler options.
3B4C386F 1E36 45EF A509 AFD60192C783 403A5D77 B209 4335 8A0C 5C61E5325954
11,313
84,047
If it ever stops raining, made this to try out. PVC, the adult version of lego blocks.
1A6050D5 C8D5 4CDA A60E 75F46F053B99 C4CC37BE 532C 4868 90E9 40AA415B6A1E 3D7B2FA4 C3F2 402F B68A 73A0B6E7E7FE
11,313
84,047
Finally got a chance to try out the water tank today. HF water pump worked great. Drove about 5 mph in 1st gear, no sweat. Full tank does two laps around track.
ED9E3B06 0E0E 48C2 9E63 AA68FF2A1BFB 15DE1C85 8BAC 4769 9597 281AF0BF25AC
11,313
84,047
995DDAD2 9E74 4B69 9B4D DD51E3CF9EF2
Finally have 600 ft of hose to pump from creek into pasture pond. HF 2 inch pump doing well, suction head of 9 ft, output head of 5 ft.
