P700 WE vs Fox Shocks?
TimmyBoy84
TimmyBoy84
56
34
Southern California
So I maybe in the market for some new shocks, the WE look awesome but the Fox seem like more of a bargain. Has anyone with the Fox Podiums run trails with 4 people in the P4? I always have mine loaded with 4 (usually the lighter bodies in back but still around 300-400lbs back there including the mutt :D). Does it handle the weight well through whoops and still not bottom out? If so I may just bite the bullet and spend the extra $$$ on the WE with the 2" shock body and larger spring instead of the Fox with the 1.5". If the Fox shocks work out I can get a couple more goodies like my Dobeck chip :D and a few more lights but the WE will eat up my budget :(.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
What are you finding for price compare?
67,508
I've got the we on the front and I'm so impressed by them my rears will be here tomorrow. I didn't go with the piggyback and the front hasn't faded one bit. No experience with the fox.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I have the fox setup. I really doubt you will have a problem with the extra weight of passengers if you adjust them correctly. I have a P-2 so I can't say for sure, but I have driven around with 300-400 pounds of feed in the bed and didn't have any problems. Of course I wasn't going through whoops either. I think either one will be a great choice to upgrade the suspension but because going with fox means you'll get to do some other upgrades, I'd be leaning towards the fox.
TimmyBoy84
TimmyBoy84
56
34
Southern California
Well I've seen the Foxs go for $1150ish+ on ebay and the WE are $460+ per shock if i go piggyback/reservoir, unless monotubes are enough cuz they're larger?
Im sure i can adjust them, the main thing is bottom out. Upgrades are pointless if i gotta slow down for every whoop lol
67,508
I haven't bottomed the fronts out they have a big rubber stopper so if you did you might not notice. Also you can tell the shock builder what your concerns are and they might be able to set up a pair for you. At least elkas do
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I don't think you'll have a problem bottoming out with either. I bottomed mine out once in the front. I was trying to test their limits (and scare my wife) so I went full throttle off a 3 foot drop to flat bottom. That did it! It wasn't even really that bad because of the rubber bump stops that are built in like @Plumber32 mentioned. If for some reason you do have bottoming out problems with either brand you can always install a heavier spring. That's something to remember with any of the high end aftermarket shocks, you can change them and customize them to your liking. But I really think the fox's would be fine out of the box with some minor adjustments. Sounds like what you really need is what I've been waiting for- a long travel kit!
TimmyBoy84
TimmyBoy84
56
34
Southern California
I figured i could always go with an upgraded spring too and i thought about calling Fox to get some more info and some answers to some of my concerns before dropping that kinda scratch for shocks lol. There's a big Sand sport expo this weekend i may go to so hopefully some of the shock vendors are there and can get some good info there too.
bagotaco
bagotaco
121
77
I put the fox podiums on the front of my 700-4 and was able to jump it a couple feet off th ground without it bottoming. I've also be in some rough rocky conditions without a problem. Very smooth. I bought mine used off a rzr 900 for $300 a pair. Looking for another set for the rear now. You won't go wrong with either set. Anything is better than the stock shocks
If you have not already and you do a thread specific on this?
That way, those of us wanting to do the same thing would know which shocks to get exactly. What year is the donor vehicle? From the donor vehicle, did you use front shocks for your shocks?
Was it a direct swap? Or did you have to do some custom work?
Thank you, Joe
Reactions: bobbyhill
TimmyBoy84
TimmyBoy84
56
34
Southern California
Yea, I think a set of slinkies would ride better than the stock shocks lol :D. Thanks everyone too for all the info, very helpful to get different points of view on everyone's set ups. Who knows, maybe I might still snag some used ones like Bagotaco too :cool::).
TimmyBoy84
TimmyBoy84
56
34
Southern California
Saw this guys ad up on CL again, may have to go check these out also. $450 for all 4 and he said they may be off a 2011 Rzr 800
Upload 2015 9 17 10 8 14
That's makes me curious if those will fit. That's why I'm hoping those that have done it can enlighten us on which donor vehicle. Will those from an 800 rzr work?
bagotaco
bagotaco
121
77
Thank you, Joe
I did a thread the title was "RZR Shocks??" It has all the info in it. Mine was the rear set of a 2012. I did have to make a simple bolt on bracket but there is another set that will be direct bolt on.
Reactions: joeymt33
bagotaco
bagotaco
121
77
I dont believe the fronts will work (rzr is lighter so the spring will sag). Those are the backs I used. The other shock they have (the ones without the piggyback ) will be the direct bolt on. Just make sure you use the rear
67,508
Curious as to how you guys have your suspension set up or how far down you screwed the adjusters
TimmyBoy84
TimmyBoy84
56
34
Southern California
So after going to the sand sport show and talking to walker evans guy I think im going to go with their monotubes all around. They're a bigger shock body and spring and if i want to upgrade to say reservoirs to fine tune them like the Foxs he say like $150 per shock. I like the larger body and spring idea for my application and trail riding i do and for all the big bodies that ride with me sometimes in the back lol.
