My dash went under water and my display got wet. I have not found any post yet for anyone else with this issue. I want to fix this problem and hopefully help someone else out before it happens to them.
First three pics show what I believe to be the issue...
The plug going into back of display case is where I think the water came through. It is designed to be able to move the cord in and out so you can unplug it from display while in case.
Mine as I'm sure all of yours does did have electrical tape wrapped around all the ends but I have removed mine. Electrical tape is obviously not enough.
In like if it were hooked up
Out so it can be disconnected easier.
Here is the issue!
Where it's designed for that, leaves this gap inside the plastics because of how they made it to slide.
I also filled display case with water to confirm no leaks
I was thinking maybe filling all the plastic plug casing with dialectic grease and use zip ties on all ends along with electrical tape.....
Any ideas questions or comments?
Here is the issue!
