Chooglin
Wife wanted some side view mirrors !
20180506 100021
43,413
Its great , isn't it ? It took me awhile to remove mine , been off for 2 yrs now and isn't going back on my machine unless I sell it !
Yeah, it is. Esp considering I went back up to the second step on the preload to help offset any possible instability I might encounter. So I can get better still.
185,365
About 15 minutes into today's ride...and that sway bar ain't going back on EVER! Noticably improved ride.
Don't know of anyone that hooked it back up after disconnecting it. How hard was it to get out? Remove the wheel?
P
Porkyrhc
Glen Allen, Va.
Every forum has to have one of these threads!!! Any new mods/maintenance/repairs/rides/wrecks (God forbid) you want to share? :)
after reading some peop[e are changing their oil from honda to moble 1 synthetic i have a question. the honda dealer tell me oil is not just for engine but also for transmission and that i should stick with the honda oil to protect it. i know they are proble just trying to sell honda products but can anyone give me advise. i have always used mobil 1 in my car and am pleased with it but dont want to mess with my trans. any help would be appreciated since its time for my 2nd oil change
Reactions: JWB and mrjeff42
43,413
Not hard if you have power tools. I say that because the hex in the link rounded when i tried to do it by hand, so I hit the nut with my 3/8 air impact.
I removed the right wheel to get the bar out just cause that's where I was.
185,365
More crap showing up and no time to put it on.
Shocks Rear
With sub
Been thinking of rearranging inside the box, just carrying the helmets in the trailer and making more room. The length of the winch cables limit the placement of the power box so thinking of running them directly to the second battery under the seat, shorter run anyway. That'll allow me to move the power box wherever I want and make better use of the space. Should find something else to put in there, would hate to leave it half empty. Hmmm...:D
luckymike
luckymike
144
322
michigan
Reactions: Dp5hunter
JWB
JWB
2,044
California MD
Use Honda oil, or an oil that meets exactly the requirements stated in the owners manual. Automotive synthetics do not meet the standards and do not have the additives needed for our relatively low tech engines. I have had the oil discussion ad nauseam with my Honda Rep, and have been told repeatedly that there is no better oil. It is tested per application for literally 1000's of hours. Honda's oils are designed specifically for the applications they are recommended for. So if you want to experiment with your $6000 engine- go ahead, but if it's under warranty, and the engine has a lubrication related failure... guess who's gonna pay for it! Try to use the Honda oil filters as well- it's one of the first questions we get asked if an engine fails under warranty. Just my 2 cents worth....;)
185,365
Sounds like a question for our in house oil specialists @joeymt33 or @KYhillbilly . If you change the oil at recommended intervals then the Honda oil is just fine. If you ever go too long, engine consistently running at high RPM's or get low oil level(all slightly abusing) then go with synthetic, IMO. I went with Royal Purple Max Cycle on the second service, I use RP in every engine I own.
Bad_bowtie
Bad_bowtie
Huge member
2,559
15,783
East Tennessee
Added the Tusk rear panel. Had to remove my gun racks and relocate my license plate. Also putting the underseat heat and sound barrier back in. For those with the rear panel, how is it in the summer? I really want it for dust, but not if we are going to burn up.
15258994480376951270694464308498
1525899618224782058312561239516
Russ989
Russ989
22,642
147,257
I have the tusk rear panel and cuts down the dust considerably. I don’t notice any extra heat with it on.
