43,581
Today, my 500 took a huge step forward when I did what Honda engineers couldn't:
20190404 200924
No more pulling 20 rivets and screws just to change the oil!
I went ahead and changed the filter, since the engine has been open 2 times on this fresh oil change. Wanted to get any dirt/dust that got trapped out
Mudder
Mudder
NTC/TAP Transition Member
11,866
90,399
Good idea @DG Rider , especially with the trigger shield. Thinking of doing same now and repurposing the OEM rubber flap from the hole under the drivers seat as a cover for the new hole, (did the trash can mod). Thinking the new flap would reduce heat flow/ build up to the ECM under the trigger shield.
43,581
Your hole is too big:p
It's from my white privilege.
I'll probably add something later.
70Bones
70Bones
888
3,779
New Brunswick Canada
Any idea why Mother Honda put "No Storage" on that panel? Suppose it gets really hot or anything? If so, should we be concerned with heat on the ECM when we have a Trigger Shield installed? Just wondering because I like your idea and will look at doing the same.
Reactions: DG Rider and Caper
43,581
So you wouldn't dull your saw as you cut the hole that Honda should have cut.
Just a guess: The fuel lines/sending unit top is very close to that area. If someone threw a some sockets or whatever in it that didn't "fit", and then plopped their fat ass down on the seat, it might get pushed down enough to break a fuel fitting off...and then spraying fuel everywhere on a hot engine. Polaris style bonfire.
Caper
Caper
7,801
11,030
Halifax Nova Scotia
I’ve had the Trigger shield for a couple years. I haven’t noticed a problem with the heat. But then again , we don’t get the heat like you get. 100 up here is unusual. I don’t know how you guys do it. :)
Caper
195,225
Caper
I'd have to say the ECM heat thing is a non issue. Several of us have been running some sort of heat shield for years now. It's also a safeguard from the sweat rolling off your back and shorting it out! :D
Mudder
Mudder
11,866
90,399
Had the same question on ECM heat and just got a PM reply from one of our most knowledgeable members that its NOT likely a issue. That said, next time I have the seat off, will look if can move it above the barrier without much trouble because I do like the idea of an oil filter access hole, but do get a lot of steam going through water holes. “An ounce of prevention...”
Caper
Caper
7,801
11,030
Halifax Nova Scotia
Hahaha. You got that right. Sooo true. :) :)
Reactions: rtn001
Caper
Caper
7,801
11,030
Halifax Nova Scotia
For you southern boys. I think us northerners are ok. :) Still, I don’t know how you do it. :)
Caper
Reactions: rtn001
Mudder
Mudder
11,866
90,399
As for the access hole. Post a picture when you get it done. Please. :). Thanks Mudder
Caper
Thanks to @DG Rider for the picture, since I just changed the oil filter, will do it next cycle and reuse the OEM rubber flap from the drivers side using a few extra push pins. Its not doing any good in the drawer.
Image 579F0BEA B5B7 4CD7 BFF6 C2C9639D3F1F
Reactions: Caper and DG Rider
