Mudder
Mudder
NTC/TAP Transition Member
11,883
90,593
A while back, Super ATV Ez steer cost me around $550 with Hondasxs1 discount. But seems like a solid unit so far.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Took the p5 along with some rubber band style sxs of some friends up to the iron range off road park in Gilbert. What a beautiful place. Not a ton of trails(only rode about 25 miles) but we rode for about 5.5 hrs playing around in the woods and mud. Tons of fun. Edit, forgot to give a shoutout to @jak9922, didnt get a pic, but the t bar made for an awesome hand hold while riding very close to tipping in a mud hole. I was very happy it was there to grab.
20170722 123917 20170722 123846 20170722 111413 20170722 104241
chrisC
chrisC
138
259
Newfoundland, Canada
On the ez steer, 220 watts is max motor rating, and not a constant draw, no where near that when driving. Only drawing depending on how much strain it's under. No battery problems here.
Thanks Mudder,
I had assumed it was constant draw. Ill see if i can get a few readings on it in use.
Thanks again ! Time to look for even more power using accessories i guess ... :D
Reactions: Dp5hunter
chrisC
chrisC
138
259
Had just got it off my mind and then there it is again...ugh! :rolleyes: How was the install Chris? How much did you find it for?
I'm in Canada and got it at a Canadian based website for fair bit cheaper than ive seen elsewhere. It's not a site sponsor ....can i mention their name ..per rules? The price was $739 Canadian.....
Burned a couple tanks of fuel in it this weekend....all smiles . Easy Steer makes a GREAT unit !
Especially good backing up in tight spots when you turn around and have one hand on the wheel
Trigger,
Without involving the heater relocation ....Im guessing the mechanical part would take 40 minutes.... For the electrical ,I just piggybacked from my winch solenoid which was in the honda provided underhood location so that took only 5 minutes. The switching wire attaches to the stock 12V power accessory outlet with a scotchlock connector.That only takes few minutes.... Mount controller with provided bracket....plug in 4 connectors to it ....Yidy up wires
So overall .....call it an hour install, much easier than i thought it would be.
If someone had to run wires back to the battery...well that's going to take a while more
WillyBill
WillyBill
Wheeling Addict
480
1,907
Clinton, Utah
  1. Talon X LV
Pulled off the sway bay, turned up the shocks one notch, and added 25" Bighorn 2.0 tires on Yamaha rims with more offset. Now 51.5" wide rear and 50.5" wide on front. Very interested to see how much this improved things.
WB
iowaguy
iowaguy
624
1,425
Eastern Iowa
WB[/QUOTE
pulling the sway bar will improve the ride.I took mine off and have no desire to put it back on
rocmar
rocmar
4,741
5,778
4 CORNERS
WB
Dude I was just in west point..Ut
last weekend...
visiting my kids / grandkids
rocmar
rocmar
4,741
5,778
4 CORNERS
Winter is gonna be here....soon
I'd of bet a dime...you wouldn't go
Another...winter without power steering
cha....ching
WillyBill
WillyBill
Wheeling Addict
480
1,907
Clinton, Utah
  1. Talon X LV
cha....ching
4 Corners is one area of Utah I haven't explored yet but that won't be the case for long. Maybe we should hook up when I come to your area.
WB
rocmar
rocmar
4,741
5,778
4 CORNERS
WB
Do it...
I'm in Farmington ,NM
area.....but anytime dude...
Desert riding is..the bomb..
there's a national forest...with
ponderosa pines..100 of yrs old...
3 hrs south of me..called
" McGaffey National Forest"......Goggle it
BadAss riding there....
let's hook up
