What did you do to/with your Talon today?
DRZRon1
DRZRon1
1,434
4,395
Absolutely correct and something I should have said. To replace those ~32 filters, I would have had to open/close the air box ~32 times instead of ~6, trouble looking for a place to happen. For those who don't have a snorkel yet - get an inspection camera/endo scope for your cell phone or tablet and use the airbox water drain to inspect your filter. This wasn't my idea but I won't 'name drop', if he wants to speak up, he can.
With the Uni on a snorkel, I can see when it needs to be replaced without disturbing anything and it takes 5 minutes to R&R a filter. I have 3 of them, so there's always a clean one ready to install.
About the clips holding the airbox lid on, they're a finger killer - :eek: The solution is a 19 mm end wrench - use the open end to release the clips and the closed end to pull them back into place, also not my idea but I don't remember where I saw it. It's pretty simple to figure it out once you're there.
U r a genius - I used a wire tie to pull them closed - work smarter not harder
  • Haha
Reactions: CID
CousinEddie
34
Kentucky
  1. Looking to buy
7285925684390199587
AMink
AMink
309
2,345
Reno, NV
I moved from a single axle to a tandem and from straps to tire straps. Heading to Moab next week.
20250417 194403
Over the past weekend some friends rode with us outside of Carson City. The other Talon has been riding with us for a while, the RZR was new to them.
20250412 133923
20250412 133941
20250412 133029
EMAW
EMAW
Mama Tried!
3,665
46,177
Kansas
Had to change tender springs. Our 2023 R2 LV lost some ground clearance with 600ish miles thanks to all the additional accessories.
Stock Fox spring rates:
F/Tenders P/N 039-00-599-1(7.07 x 3.00 x 350#)
F/Main P/N 039-00-670-1(14.5 x 3.00 x 225#)
R/Tenders P/N 039-00-452-1(6.95 x 3.00 x 250#)
R/Main P/N 039-00-454-1(15.9 x 3.00 x 250#)
Went with EIbach, 8in x 3.00 x 400# for the front and 8in x 3.00 x 300# in the rear, to reclaim the stock ground clearance and geometry.
Also checked the Nitrogen PSI.
R/F 80
L/F 100
R/R 90
L/R 75
Installed J-C Racing schrader valve caps. Refilled the reservoirs with 100 psi (per Fox).
The ride quality definitely has improved!
