Dont upgrade tie rods. It transfers energy to more expensive parts that are harder to fix on the trail. My advise would be to take a extra with you.Well, it took way longer than I thought but....bent a tie rod this weekend. I was able to fix it and get out from 8 miles back so, there's that but I now want the best I can get!
I looked at the Savage Hiem rods but would love a grease ball joint.
Any suggestions?
I was considering this as well, these rods are weak as cold piss!
I think I need a Talon!
Yes and I happened to have raised the tire air pressure up to 12 PSI from about 4-5 PSI. I hit a little stump under the waterline in a puddle. I've hit much worse so I'm blaming the higher air pressure. I bought two new arms and keeping one with me in the repair kit.Aren't you running portals and 30+" tires? I'd let the tierods absorb and dissipate impact instead of the portal or steering rack. Much easier and only $20 for a tierod. I look at it as a fuseable link.
I bought them yesterday (Saturday) at a Honda Dealer and they had their first Talon (R) at front of the entrance. I sure wish the Pioneer steering arms we're designed like the Talons! LOL
On another note: I'm not all impressed with the Talon, it's smaller in real life and was a little tight for me at 6'4" tall.
As I've said a thousand times here about the Portal subject: where I ride, I'd need lift and tires on a Talon. Looking at the Talon, you'll definitely need forward new A Arms to put larger tires on, just like the Pioneer. I couldn't spend a lot of time as I had people waiting for me but, it looks like the Talon only has 2 wheel drive or i4 wheel drive? No turf? Is that true? I'm sure this was discussed but I must have missed it.
Depends on your definition of larger tires 30’s fit no mods depending on the manufacturer 32’s might fit because they aren’t true 32’s.
The cuckold man is complaining about Portals again?Yeah, but in your opinion portals are a good idea... sooo there’s that.
Off topic here but how many people here run portals vs IGR? Seems they are both great ideas and work for different environments, both have pros and cons. The biggest cons for portals are cost, extra width, and hard on suspension, but IGR is not perfect either. IGR means moding the cover plate (harder to return to stock), needs speed sensors, and the transmission solenoid adjusted to shift correctly. Just wondering has a poll ever been done on how many are running what.
Don't have the answer you're looking for but as to Portals, yes they are expensive but as stated above, I'm swamp and mud, it wasn't an option to not run them and stay up with the crowd. My area has mud buggies and they purposely try to f*** up the trails and a stock machine will not get through 3/4's of the trails. Maintenance is: change the oil about every three to four rides, 8 hour rides. Sounds hard but it takes 20 minutes and a quart of 80 90 gear oil.Off topic here but how many people here run portals vs IGR? Seems they are both great ideas and work for different environments, both have pros and cons. The biggest cons for portals are cost, extra width, and hard on suspension, but IGR is not perfect either. IGR means moding the cover plate (harder to return to stock), needs speed sensors, and the transmission solenoid adjusted to shift correctly. Just wondering has a poll ever been done on how many are running what.
I get anywhere with turf and Portals, only the worst deep mud gets the i4WD. Stock Honda's in my area are lucky to make 1/2 the trails with 4 wheel lock, if they don't swamp in the water. Yeah, we have to "Submarine" them here but, it's part of the fun!Now for y’all who really want to get power to the ground install IGR, 8” portals AND TRACKS!!!
I’m just saying you could probably get anywhere in Turf mode
