P1000 When a snow plow isnt enough
P1K5Dave
P1K5Dave
2,165
8,091
Petoskey, MI
I'm thinking about going with one of these on the Pioneer
Screenshot 20210827 203217
P1K5Dave
P1K5Dave
2,165
8,091
Petoskey, MI
Problem though: it's 60" wide and my tires are around 68.
Reactions: Lady01
rickoshea
i had a front mounted snowthrower on my craftsman mower.i mounted it one winter but never used it once.i ended up selling it.pita to remove the cutting deck and mount the blower.
Reactions: Lady01 and Vikes79
G
GreatNorth
83
Canada
Yeah, if you get enough snow to need a blower, that's probably not going to work well--a little wider than wheels would be more like it. If your accumulation is low enough that you won't get any real banks, a blade is generally quickest.
KevP700-4
KevP700-4
249
609
Northern MI
IF the snow is light and fluffy, you live near the county line, the wind blowing in the right direction, and if it's Beaufort 12 or better. Then maybe! :)
Haha. Really, it will throw anything 60ft +, but will also strip the small branches off the trees as well should they get in the way. Great machine though, can really move allot of snow quick.
StewB
StewB
662
3,071
For me, my snowplow is enough.
I built a dolly that holds the push tubes at the right height for the undercarriage pins.
Makes it easy to attach, detach and wheel out of the way.
1630768635800
1630768667395
The pull handle between the springs will let you shift left or right 45 degrees.
The wear bar along the bottom of the blade is reversible and replaceable.
My place is at 8,000 in the Wasatch mountains and I've had this for 6 years.
It's holding up very well for the amount of use.
G
Gunsite Guy
109
367
Trinidad, Co
I wanted to post a special thanks to stewB for his idea on building a dolly for when the plow/push tubes are off the machine. I had to go find and purchase the wheels but it was a breeze to fabricate.
Much Thanks!
s/f Steve
Scoop
Scoop
4,213
15,748
  3. Talon R LV
Harbor Freight has a boatload of different shapes, sizes, composition and capacities of wheels, and at a great price.
I built these so I could move the pontoon boat around the pole barn during the winter. The added height lets me put the 150HP Yamaha outboard completely vertical without extended the needed length of the vessel. HF wheels.
Wheels
bumperm
bumperm
1,848
6,641
Gardnerville, NV
A word of caution re. making dollies. I welded up one for the backhoe attachment on my Kubota tractor. I weighs something like 900 lbs, so I was careful in picking wheels that were rated for the load, choosing a urethane tread. That was a mistake, as rolling on my smooth concrete floor proved to be difficult. This was due to the hard durometer plastic compressing on the bottom. To move meant that compressing had to "move along" the plastic. Going to steel wheels made rolling a breeze, so long as there's no rocks or gravel in the way! Of course the hard wheels are no good for soft surfaces, but then my old bod' ain't good for moving a hoe (any kind, BTW) if I gotta push hard. Oh, I'm sorry I said that.
Cooliodaggett
Upper Peninsula
Anyone have any feed back from Northern Michigan and their 1000-5 for snow plowing?
I live in the UP. I don't use mine for plowing but I do drive it all winter. I think it would a do a great job. I drove it through a lot of deep snow last year and it walked through it like nothing. Only problem might be windows fogging up while driving slow
Reactions: Lady01
Dasmoeturhead
Bet it gets cold up there. Winters bad enough here in TN. Take care and enjoy them rides.
Reactions: Lady01
Scoop
Scoop
4,213
15,748
  3. Talon R LV
Yup. Know your material (solid rubber, pneumatic rubber, nylon, polyurethane, PVC, steel, etc.), your payload (per wheel), wheel size and know your intended surface. Not rocket science, but if you don't pay attention, you could be in for a world of hurt.
Reactions: Lady01 and StewB
Luckybeer
Luckybeer
24
48
Canada
Have a KFI 72" plow... we get a huge amount of snow, 8 month long winters.. It has never had a problem...I should note that I do have chains also which helps alot
Reactions: Lady01
