P1000 When do you use Low gear
Flgator_80
Flgator_80
274
423
Lexington, Tn
Went out on some trails for the first time yesterday and used mostly high with sport mode. When we got to some steep hills I dropped into low. Only the really steep ones needed it though. So is being in high going to cause any damage? I liked the sport might try some manual next time.
Reactions: Lady01
Cheesedictator
Gilbert, Arizona
What about when driving with 4 passengers? So 5 people total, plus a cooler most likely. Would you guys recommend using mostly low gear for that situation?
Reactions: Lady01
61,557
Depends on the terrain. If you're riding around your neighborhood, fire roads, fast trails, etc where you'll be going faster than 15-20mph or so High will be fine. If you're going up lots of inclines, crawling along a trail or through mud use Low. Like @ohanacreek mentioned, you can run up to 33mph in Low, so there's no harm in using it.
Cheesedictator
Gilbert, Arizona
Awesome thanks for the input! In arizona I’m mostly in sandy washes with mild hills and climbing so sounds like I’ll just keep it in low for sure with that many people. Just bought a 2016 P1K-5 deluxe and I’m itching bad to pick it up Thursday and take it out this weekend! It’s already had the clutch fix and I don’t like being hard on my vehicles so I’m feeling pretty good about it! Happy to have a Honda, cheers!
Reactions: Lady01 and CID
mikiemanna
north bay ontario
When you're on a snow covered lake do you have to stay in low gear? What if you can get up to 50km/hr can you just stay in high?...without damaging anything...
thanks
Reactions: Lady01 and ChadD
N
nsmitch
14
71
Spruce Grove, AB Canada
I use it when gathering a little firewood for winter or when pulling out our moose.
IMG 1316
tromano1706
tromano1706
38
157
Virginia
I use low most of the time as trails around here are very slow and rocky. Running these trails in high will definitely smoke the clutches. I have heard that if you are planning on riding under 10 mph you should use low as the clutches fully engage around 3 mph instead of 5-7 mph in high. I also never leave it in auto as it shifts way too much for my liking. I like to bog it more especially since it has a lot of torque.
Reactions: Lady01
Dlm456
Dlm456
10
Oklahoma
I have a 2018 LE, and low used to be annoying with all the shifts, and like most I would use manual, however once I got 1500 or so miles the shifts in both low and high became much smoother and less annoying. Does this seem normal? Anyone else experience the smoothing out of shifts? I worry about my clutch, it doesn't seem to ever slip and for the most part if I'm going under 20 I'm in low. I also run mobil 1 motorcycle oil.
Reactions: TripleB and Lady01
5,558
25,573
When I'm lugging down, a steep climb for instance, I'll paddle down, if it doesn't have a lower gear, I should have been in Low range. I don't want the machine slipping the clutch to keep running. Generally, if I know speeds will be under 25 or so, I'll be in Low unless it's easy forest roads then I don't think it matters.
Reactions: Lady01
TripleB
TripleB
16,358
148,194
Caryville, Tennessee
When I used low I always had to be in manual for the reasons you stated. After over a year and maybe 2000 miles I tried it in auto while in low and it shifts mostly like I want. I just assumed the computer learns your driving style but idk. The only time I use manual in low now, is when I'm climbing steeps or hitting mudholes that have to be hit kinda hard. An untimely up shift in one of those scenarios can equal failure. I still constantly paddle shift while I'm in auto when I need to. Especially down hill for braking purposes.
