P1000 Which Isolators Were Potentially Causing Fires?
N
Nvrgiveup
I know darn well I saw it in here somewhere last week, but I can't seem to find it again. Which battery isolators were suspected of causing fires?
Reactions: Lady01
bumperm
bumperm
1,906
6,788
Gardnerville, NV
Could it have been the "IsoArsonator"?
Sorry, couldn't help myself. I have a True isolator, probably the most popular option from what I've read. Easy to install, well thought out, effective.
  • Haha
Reactions: Farmer and CID
67,170
None that I know of.
But all of them if wired incorrectly.
One guy has his wired to a ground.
I have sold a few 1000 of the TrueAM Isolators.
While there have been a few bad ones, like any product, nothing major.
Most of the bad ones had water damage from a cracked case.
Usually around the 2 screw mount holes and appeared to be over tightened and cracked.
Reactions: Lady01 and Scoop
N
Nvrgiveup
Wired to Ground?! Surely you looked at it wrong. I'm plum retarded but even I have enough sense to know better than to do that!
Reactions: Lady01
67,170
It was to the starter side of the starter solenoid.
It is only hot during cranking, Otherwise it test as a false ground.
He ment to put it on the battery side.
I seen it in his pictures and told him. lol.
