P1000m5 WILDCAT (Formerly New Blue)
Byrdman
151
215
Kentucky
Finished up all the heat wrap in back and behind seat. Took it out for a ride for about 15 min or so. I didn't feel any heat in the front seat rising up. When I got home I felt around in the back and only felt heat in hole where seats latch in middle. I will have to talk my wife into riding back there to get honest feedback. I hope between this and wiring my fan the rest of the way it fixes issue
Byrdman
151
215
Kentucky
Non lighted stainless cup holders installed. 0d24a5e6c26c3c515b83411a4db405cf
Byrdman
151
215
Kentucky
Ok help me out guys. I have my switch panel and I am installing a 12 volt car charger outlet and a USB charger outlet with two ports. Can both of these be wired to same fuse or do they need to be separate? What size fuse if combined or if I have to fuse them separately? Thanks in advance
39,079
I would think it's ok. 10-15 amp should be fine. Just Match the wire gauge to the fuse size.
CP: I've been saying that since that jack wagon was picking Legos from his turds:)
Byrdman
151
215
Kentucky
Thanks man.
Reactions: joeymt33
Byrdman
151
215
Kentucky
Ok guys need some help. Got my winch 7 pin rocker switch today to complete my panel. I have switch grounded and the led light up with my key on. I'm trying to find the winch in/out wires. I had a switch they mounted in dash I cut it but it only has green black wire. Also tried coming off yellow wire from solenoid but that didn't seem to do anything
Byrdman
151
215
Kentucky
It looks as if I cut wrong cord. Should have cut cord after the plug in that goes up to hand held switch I could use outside the utv. I opened the switch and it has blue brown and yellow wire in it. I guess I'll put cord back I cut in half and splice into the cord with three wires. If this doesn't sound right let me know
Byrdman
151
215
Kentucky
Nothing majorly difficult with this oil change. I didn't see anything crazy on filters either.
Byrdman
151
215
Kentucky
Took the plunge and bought fox shocks for all four corners. Also got front mud flaps on the way. Going to try and make my own mudbusters for the back because I can't justify 180 bucks (yet) for a piece of plastic. Still working on my bed extender as well. Hope to have it done by next week.
208,013
You won't be sorry, if you don't have 8 ply's you will.
208,013
Tires are stock atm. 8 plys that good?
I busted two stockers, after I got my Elka's the front lasted three rides before I busted another. And was running 14 PSI. You'll probably pick you'd speed up, it will handle sooooo much better.
Byrdman
151
215
Kentucky
Here is one side of my own rear mud flaps. I have to remove and cut the arc back some towards the rear roll cage because bed won't open all the way but other than that, I'm super pleased. 88f986b27c45012fb945a7d5e005112832fe94069b315803e6245f20555599f9
Byrdman
151
215
Kentucky
Rear fox shocks and sway bar removed. Took for a quick ride down a trail and I can tell a difference in how the rear end feels and now how the wheels drop down in ruts. I'm very pleased so far and gained an inch height as well in the back.
Similar threads
