That's what I thought but I assumed bumperm knew more info than I didI think he meant the wheel not the stickers 🤣
Sure you can mount those with that tire. Same tire @BWAF has i believe?View attachment 282961I am wanting to mount 235/75/15 all terrain tires to these wheels. Will that combo work on a stock 2021 pioneer 1000-5?
OK I believe my avatar is updated with a pic of the machine. The two things that are a little different with this wheel is it is a 6' rim and the offset is listed as +38MM. Just wanting to check if either of these would make a difference, when mounting on a stock machine?Sure you can mount those with that tire. Same tire @BWAF has i believe?
welcome the forum anyway!
Tanks for the pic of the rim, but u missed the most important pic…your machine!!
as the 1st bible verse of the forum says….
PICS OR IT DIDNT HAPPEN!5
Everybody gets all wicked technical about offset lol. The way i did it is, if i like the rim and its lugs are for the P1, I bought them then if i needed some spacers (9 times out of 10 u will anyway when your going larger than the stockers) depending on how much bigger than the stockers you go, your gona need new Arms to not rub and shocks to not bottom out. Got to work smarter not harder!OK I believe my avatar is updated with a pic of the machine. The two things that are a little different with this wheel is it is a 6' rim and the offset is listed as +38MM. Just wanting to check if either of these would make a difference, when mounting on a stock machine?
The diameter of the tire is too large. You will need front forward arms. With the wheels choice its hard to say if you may need spacers as well. That will most likely be a trial and error fitment. The rear should fit fine.View attachment 282961I am wanting to mount 235/75/15 all terrain tires to these wheels. Will that combo work on a stock 2021 pioneer 1000-5?
Yes, but either way u will need spacers, and preferably shocks imo if u go with anthing bigger than a stock tire. Eventually you will rub someplace doing something not b happy and be right back here like all the rest asking whats the fix? lol.Thank you for all the replies. I should have given the main use for my machine and asked for options rather than would this particular tire/rim combo would work. Not sure if I should start a new thread or not, but I will just ask here. this machine will be on pavement or logging roads 99% of the time, so I am looking for the most economical way to get a common size all terrain tire that I can rotate. I like the looks of the rims pictured and 15 inch tires are pretty common. I don't want to add anything other than wheel spacers. Could I use the rims pictured and get a smaller tire maybe?
I have just the basic model with 12 inch rims, 27 inch tires, and factory shocks.Yes, but either way u will need spacers, and preferably shocks imo if u go with anthing bigger than a stock tire. Eventually you will rub someplace doing something not b happy and be right back here like all the rest asking whats the fix? lol.
what machine do u have? LE, Deluxe? Stock shocks aftermarket?
So youll prob want some sort of sispention/drivetrain upgrade. Be it Arms, shocks, spacers. Id deff do shocks for ride quality and preload to get u some clearance and then add some spcers if beed be? If u need clearance and dont have the money or dont want to buy shocks, id add some shock spacers to the stockers. There is threads on here as to how to do that.I have just the basic model with 12 inch rims, 27 inch tires, and factory shocks.
Thank you, I will look at the shocks first and then go from there.So youll prob want some sort of sispention/drivetrain upgrade. Be it Arms, shocks, spacers. Id deff do shocks for ride quality and preload to get u some clearance and then add some spcers if beed be? If u need clearance and dont have the money or dont want to buy shocks, id add some shock spacers to the stockers. There is threads on here as to how to do that.
No prob! Good luck, if u need anymore help just askThank you, I will look at the shocks first and then go from there.
use code taketen for $10offThese guys are neat to work with. I have worked with them a couple of times. I got my truck wheels and pioneer wheels from them
4x137 Bolt Pattern Wheels at Extreme Customs
Extreme Customs! One of the fastest growing aftermarket accessory companies online! We ship thousands of wheel and tire packages and accessories each year!www.extremecustoms.com
If you chat with them they will discount almost anything.
You need forward arms to fit bigger tires on front. You do not need anything on the rear.
P1000 - I like the best deals:High lifter control arm deal!
As the title describes I like deals, coupons, promos, whatever you call it to get good prices. I just wanted to pass this along in case anyone else is looking for a neat deal. This is the high lifter arched control arm for the rear of the pioneer 1000. I was able to get it thru an offer of 175...hondasxs.com
@SuperATV also can give discount codes for their website if you prefer their brand of arms.
@RB3offroad has good spacers from what I hear.
How much do you want for those 12 inch wheels? What part of Tennessee?I have just the basic model with 12 inch rims, 27 inch tires, and factory shocks.
