I'm looking too for my 2020 deluxe. Narrowed down to viper, kfi, or super winch. I dont want or need top of the line, just 4500 lbs that is reliable. Will use mostly for plow lifting.Hello Everybody,
I'm curious about everyone choice of winch and why. What where the driving factors of your decision. price, reputation, ease of use. Or you think a winch is a waste of money.
My self. I have a KFI products SE45-R2 (4500lb).
I learned something when I bought my 4500 Warn AXON and was considering a 5500 AXON. They both draw the same amps at full load.
The reason is the gearing. The 5500 is geared down more to get more pull at the same amps (250ish amps IIRC). You can see it on the rated rope speed. I decided to go 4500 for that reason, figuring I could employ a snatch block if I needed more pull, but that most of the time I'd want speed over tonnage.
Your best answer may be different from mine. But consider the rope speed vs pull rating tradeoff.
