P500 Winch question
Sbrown
Sbrown
Tennessee
Will the four assessory wiring harness power a winch or does it need to go straight to the battery?
Reactions: Elkhunter
O
oldfortyfive
606
1,371
Illinois
The harness powers a relay which has wires to the battery.
allgm1
allgm1
1,049
1,484
New Hampshire
winch gets wired back to the battery, the accy harness is for small accy.
Sbrown
Sbrown
Tennessee
So is best for me to go straight to battery from the winch?
182,189
@Sbrown ... Your winch has a solenoid, mount that under the hood somewhere, wire from the winch to the solenoid, solenoid back to battery. Use cables supplied with winch or get some good stuff. Winch draws a lot of power, don't want to skimp on that and burn it up.
Reactions: sharp
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
I bought a good set of 6 gauge jumper cables and cut the ends off and used it. Both wires together, thick coating and easy to run. Dedicated for winch, mounted the sealed solenoid/wireless control box to cross member near dash.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
agreed, kind of a pain getting the heavy gauge wire into the battery box and getting the box cover back on but with some patience it can be done.
Reactions: trigger
182,189
IMO, install a power block somewhere for future hook ups. Then you only have the two cables running into the battery box.
And there will most definitely be future hooking up! ;)
Reactions: chrisC
Chooglin
Screenshot 2016 03 17 07 14 31
