Welcome Rooster to the community.
I mounted mine is same spot but on the opposite side.
Make sure you pre-wire it up to insure you have enough wire before you secure it in it's final place. I had to move mine 2 inches to allow the wired to fit after I mounted it.
It did require using the long wires for the (battery to contactor). Where normally these are the (contractor to winch) wires.
